Eclipse Community ForumsWebservice in eclispe RCP
https://www.eclipse.org/forums/index.php/mv/msg/72861/227753/#msg_227753
My develope envirement is eclise 3.4.
and use axis 1.4.
Web service created by Visual Studio 2008 and .Net frame 3.5.
I created java source from eclipse using webservice client creation
wizard.
In swing, It's OK.
But in eclipse rcp not ok.
beleow message issued.
Plz . Help me.
2009. 2. 12 ¿ÀÈÄ 10:40:44 org.apache.axis.client.Call invoke
Severe: Exception:
org.xml.sax.SAXException: Invalid element in
org.datacontract.schemas._2004._07.GLAB_DAC_Default_Equipmen tInput_BE.ArrayOfRsdOrderBE
- RsdOrderBE
at
org.apache.axis.encoding.ser.BeanDeserializer.onStartChild(B eanDeserializer.java:258)
at
org.apache.axis.encoding.DeserializationContext.startElement (DeserializationContext.java:1035)
at
org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRe corder.java:165)
at
org.apache.axis.message.MessageElement.publishToHandler(Mess ageElement.java:1141)
at org.apache.axis.message.RPCElement.deserialize(RPCElement.ja va:236)
at org.apache.axis.message.RPCElement.getParams(RPCElement.java :384)
at org.apache.axis.client.Call.invoke(Call.java:2467)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at
kr.co.gcrl.gclab.DAC.BasicHttpBinding_IRsdDACStub.selectRsdO rder(BasicHttpBinding_IRsdDACStub.java:751)
at kr.mycube.pub.wsdl.RsdDACClient.selectRsdOrder(RsdDACClient. java:45)
at
kr.mycube.framework.ApplicationWorkbenchWindowAdvisor.postWi ndowOpen(ApplicationWorkbenchWindowAdvisor.java:41)
at
org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(Wor kbenchWindow.java:1229)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:786)
at
org.eclipse.ui.internal.Workbench$22.runWithException(Workbe nch.java:1041)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:132)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3798)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3423)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:177)
at
org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4249)
at
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1356)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2312)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at kr.mycube.framework.Application.start(Application.java:26)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userExcept ion
faultSubcode:
faultString: org.xml.sax.SAXException: Invalid element in
- RsdOrderBE
faultActor:
faultNode:
faultDetail: {http://xml.apache.org/axis/}stackTrace:org.xml.sax.SAXExcep tion: Invalid
element in
- RsdOrderBE
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
- RsdOrderBE
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.apache.axis.client.Call.invoke(Call.java:2470)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.xml.sax.SAXException: Invalid element in
- RsdOrderBE
at
at
at
at
... 41 more]]>kisung,baek2009-02-12T13:47:50-00:00
