Eclipse Community ForumsForm generator in Eclipse
https://www.eclipse.org/forums/index.php/mv/msg/714741/1315981/#msg_1315981
Can I ask what is the best way to automatically generate forms in Swing with WindowBuilder for Beans?
I have found the "Swing Automatic Databinding" Wizard which on the surface seems to be perfect however I have some reservations.
1. Binding of non String properties such as BigDecimal, Double in the Bean does not seem to work using the automatic generation wizard and I have not been able to find any documentation on this. Can someone please advise any relevant resources?
2. It sees to automatically map directly to the bean which is not necessarily what I am after. I would like an OK / Cancel scenario to back out of the changes in case they are not desirable.
3. Is this feature likely to be supported going forward in Eclipse?]]>Ed Murray2014-04-26T07:58:34-00:00
