Eclipse Community ForumsArrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/215744/#msg_215744
Originally posted by: gd.bill.com
Stupid question: I see a yellow arrow in the margin of the Java editor.
Sometimes it obscures a breakpoint marker, for example. Could someone tell
me what this icon indicates, or, better yet, where in the help I might find
an answer to this question (I've gotten nowhere finding anything about this
in the help).
Any info appreciated.
TIA
Greg Safford]]>2007-06-14T14:37:45-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/215759/#msg_215759
Greg,
You mean the "yield sign" marker that indicates a warning in the Java
code? If you hover over it, it will tell you what it's for...
> in the help).
> TIA
> Greg Safford
>]]>2007-06-14T14:44:18-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/215791/#msg_215791
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> in the help).
Sounds like an instruction pointer. I.d. you have a debug process
running, and the arrow indicates where in the code you are. If the
process stops at a breakpoint, then it might be over the breakpoint
symbol. Hovering over the symbol will show you all markers in the margin.
iD8DBQFGcWKse+7xMGD3itQRAlKPAJwPjbO9+SiAH6oc+H337WnCjjgkkQCf eEel
aL/oH9nrWtra8A3i0/EmdYs=
=j9Er
-----END PGP SIGNATURE-----]]>2007-06-14T15:45:48-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/216290/#msg_216290
> in the help).
If you open Help Contents and search for "icons" it returns several
pages that describe the various groups of icons. The one you're talking
about might be there. If you can't find it, post a small image of it and
I'm sure someone can identify it for you.
Hope this helps,
Eric]]>2007-06-16T03:05:03-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/216584/#msg_216584
I think it's probably a search result indicator. If you do a multifile
search, or a Find References, it gives you the list of results in the
Search pane and it also puts a yellow arrow in the margin beside each
found occurrence. It's easy to forget that you have an active search and
so those arrows can seem to appear out of nowhere. To dismiss them, just
close the Search pane.
Peace,
--Carl]]>Carl Manaster2007-06-18T21:38:04-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/216720/#msg_216720
Thanks much. In searching previously, I made the stupid error of forgetting
to change the scope to 'All', but now I see that you are right.
The yellow arrow is indeed the search results icon.
Greg
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:f4vk0v$i8m$1@build.eclipse.org...
>> tell me what this icon indicates, or, better yet, where in the help I
>> might find an answer to this question (I've gotten nowhere finding
>> anything about this in the help).
> If you open Help Contents and search for "icons" it returns several pages
> that describe the various groups of icons. The one you're talking about
> might be there. If you can't find it, post a small image of it and I'm
> Hope this helps,
> Eric]]>2007-06-19T17:13:26-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/216728/#msg_216728
Plausible, but turns out to be the search results marker.
Thanks for the suggestion.
Greg
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f4rk81$fmq$2@build.eclipse.org...
> Greg,
>> TIA
>> Greg Safford
>>]]>2007-06-19T17:16:15-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/216736/#msg_216736
You are correct Sir.
Thanks much.
Greg
"Carl Manaster" <manaster@pobox.com> wrote in message
news:d49876a1f6f6719b7060e195f9d6c7d0$1@www.eclipse.org...
> Hi, Greg,
> Peace,
> --Carl
>]]>2007-06-19T17:18:18-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/216744/#msg_216744
As it happens, the arrow is the search results pointer.
But I've run into the debug indicator as well. Thanks for the suggestion.
Greg
"Hendrik Maryns" <hendrik_maryns@despammed.com> wrote in message
news:f4rnou$oq9$1@build.eclipse.org...
> Hash: SHA1
>> tell
>> find
>> this
>> in the help).
> H.
> Hendrik Maryns
> http://tcl.sfs.uni-tuebingen.de/~hendrik/
> http://aouw.org
> Ask smart questions, get good answers:
> http://www.catb.org/~esr/faqs/smart-questions.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.5 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> =j9Er
> -----END PGP SIGNATURE-----]]>2007-06-19T17:19:10-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/755879/#msg_755879
Stan Sokolov2011-11-09T23:37:03-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/756060/#msg_756060
Raji Abraham2011-11-10T17:34:38-00:00Re: Arrow icon in the Java editor
https://www.eclipse.org/forums/index.php/mv/msg/68814/756131/#msg_756131
> Search markers remain as long as there are search result entries in
> the Search View tab. Closing this tab or removing search item(s) from
> this view will remove the corresponding search marker(s).
Or you choose not to show them at all on the General > Editors > Text
Editors > Annotations preference page.
