Eclipse Community Forumsorg.eclipse.ocl.examples.feature.group in target platform
https://www.eclipse.org/forums/index.php/mv/msg/672400/1271103/#msg_1271103
I want to use <unit id="org.eclipse.ocl.examples.feature.group" version="0.0.0"/> in my target platform. Unfortunately I run from one missing dependency into the next one. For me it looks mainly like XText is messing things up here. I now have added <unit id="org.eclipse.xtext.sdk.feature.group" version="0.0.0"/> and <unit id="org.eclipse.xtend.feature.group" version="0.0.0"/> from the luna repositories and <unit id="com.google.inject" version="0.0.0"/> from the orbit repositories. Is there an example target platform for usage with ocl examples or do I need to go on adding dependencies by using try and error?
Ralph]]>Ralph Gerbig2014-03-14T09:14:03-00:00Re: org.eclipse.ocl.examples.feature.group in target platform
https://www.eclipse.org/forums/index.php/mv/msg/672400/1272165/#msg_1272165
to get it running one needs to set all update sites to planner. I had it for the Luna only. I hope this helps others running into the same Problem
Ralph]]>Ralph Gerbig2014-03-17T08:31:10-00:00Re: org.eclipse.ocl.examples.feature.group in target platform
https://www.eclipse.org/forums/index.php/mv/msg/672400/1272173/#msg_1272173
Sorry, I seem to have missed your original message.
Looking back at it I don't really understand, and I certainly don't
understand your solution. What is 'planner'.
Perhaps you can write something a bit clearer for me and others. Then
maybe I'll put it on the FAQ.
Ed Willink
On 17/03/2014 08:31, Ralph Gerbig wrote:
> Problem :)
> Ralph]]>Ed Willink2014-03-17T08:51:32-00:00
