Eclipse Community ForumsLine delimiters
https://www.eclipse.org/forums/index.php/mv/msg/65062/204741/#msg_204741
Originally posted by: jan.bares.ips-ag.net
can I configure Eclipse line delimiters for jsp files to use the same
delimiters as are already present in edited file? There are no such
settings in Web and XML/JSP files, line delimiters. When I open jsp file
with UNIX line delimiters, I want to use UNIX line delimiters for new
lines and vice versa no matter the platform Eclipse is running on. This
feature works fine for *.java files, why is this changed in wtp?
Thanks Jan]]>2007-11-20T08:50:09-00:00Re: Line delimiters
https://www.eclipse.org/forums/index.php/mv/msg/65062/204792/#msg_204792
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <089bf703f60427cee8c3c970c102fccf$1@www.eclipse.org>, jan.bares@ips-ag.net says...
There are lots of things in the UI that don't work the same for .java
files as they do .jsp files.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).]]>2007-11-21T13:24:23-00:00Re: Line delimiters
https://www.eclipse.org/forums/index.php/mv/msg/65062/204799/#msg_204799
--------------060106040902080407030602
I'm sure that's true, but I think the desire to preserve the line feed
conventions of an existing file is a reasonable one and this is
supported by most of the rest of Eclipse. If that's not working
properly in this context, I'd open a bugzilla about it. I know for
EMF's generator we added support so that regenerating a file matches the
conventions already used by that file rather that using some global
preference or the OS's default.
>> Hi,
<html>
<head>
http-equiv="Content-Type">
</head>
supported by most of the rest of Eclipse.]]>2007-11-21T14:07:25-00:00
