Eclipse Community ForumsActive Process and Timer
https://www.eclipse.org/forums/index.php/mv/msg/641477/1236617/#msg_1236617
We have a process which runs every 10 minutes using the Timer trigger. We have noticed that when the process execution is not completed for some reason, all the future process instances also do not get executed. The Daemon runs at every 10 minutes but is is not able execute the process instance when the previous run is not completed for some reason.
The solution is to manually restart the IPP web app.
Any idea?
Rahim]]>Rahim Kanjiyani2014-01-27T17:29:35-00:00Re: Active Process and Timer
https://www.eclipse.org/forums/index.php/mv/msg/641477/1236788/#msg_1236788
have you considered
- adding an error event handler for the failing activity instance(s)?
- starting another (sub) process asynchronously and completing the scheduler instance immediately
- restarting the daemon (e.g. using the daemon watchdog approach from the knwoledgebase)instead of the web app
Best regards
Rob
]]>Robert Emsbach2014-01-28T04:19:09-00:00Re: Active Process and Timer
https://www.eclipse.org/forums/index.php/mv/msg/641477/1237000/#msg_1237000
]]>Rahim Kanjiyani2014-01-28T15:48:49-00:00
