Eclipse Community ForumsThe title of the dialog message does not appear ?
https://www.eclipse.org/forums/index.php/mv/msg/637639/1231896/#msg_1231896
Templates Hello, World Command.
Run Eclipse Application.
public class HandlerUn extends AbstractHandler {
public Object execute(ExecutionEvent event) throws ExecutionException {
IWorkbenchWindow window = HandlerUtil.getActiveWorkbenchWindowChecked(event);
MessageDialog.openInformation(
window.getShell(),
"Plugin 582", // *
"Test du plug-in 582");
return null;
SYSTEME : Linux x86_64 3.2.0-4-amd64 wheezy { debian-7.1.0-amd64 }
IDE : eclipse-standard-kepler-SR1-linux-gtk-x86_64.tar.gz
JAVA : java version "1.6.0_45"
* The title of the dialog message does not appear?
File Attachments Plugin 582.png | ]]>faath claude2014-01-15T17:34:09-00:00Re: The title of the dialog message does not appear ?
https://www.eclipse.org/forums/index.php/mv/msg/637639/1233677/#msg_1233677
If you are using Gnome3 try to uncheck this option using dconf-editor:
org.gnome.shell.overrides.attach_modal_dialogs
Marco.]]>Marco Maccaferri2014-01-20T09:05:21-00:00Re: The title of the dialog message does not appear ?
https://www.eclipse.org/forums/index.php/mv/msg/637639/1233761/#msg_1233761
The title appears in MessageDialog with org.gnome.shell.overrides : attach-modal-dialogs : FALSE.
Thank you for the information.]]>faath claude2014-01-20T12:18:28-00:00
