Eclipse Community ForumsIWAB0489E Error when deploying Web service to Axis runtime
https://www.eclipse.org/forums/index.php/mv/msg/63688/200730/#msg_200730
Originally posted by: listacctc.gmail.com
I keep getting this error:
axis-admin failed with {http://xml.apache.org/axis/}HTTP
(404)/MyService/services/AdminService
when trying to test a web service project from eclipse. The eclipse
install is only a couple weeks old. I've had this same service deployed
successfully, but now this is happening.
I've googled around a bit and this has been a problem in the past but it
seems as though it had been patched and subsequent versions were going
to be fixed.
I've tried refresh, clean, starting eclipse with the -clean flag,
nothing seems to be working.
Does anybody have any insight? Any help would be appreciated.
Thanks.
Windows XP
Eclipse Version: 3.3.0
Build id: I20070621-1340
Tomcat 5.0
JDK 5.0]]>2007-09-28T18:00:44-00:00Re: IWAB0489E Error when deploying Web service to Axis runtime
https://www.eclipse.org/forums/index.php/mv/msg/63688/200804/#msg_200804
Originally posted by: paradies.transit-online.de
Sorry, no help, no idea ... same for me while trying to generate a web
service with Axis2.
My configuration:
Windows XP
Eclipse v3.3.0 build M20070921-1145
WTP v2.0.1
Axis2 v1.3
Tomcat v5.5.23
Java v1.6.0_02
Any help would be appreciated,
thanks,
Thomas
> to be fixed.
> Thanks.
> Windows XP
> Tomcat 5.0
> JDK 5.0]]>2007-10-01T08:14:29-00:00Re: IWAB0489E Error when deploying Web service to Axis runtime
https://www.eclipse.org/forums/index.php/mv/msg/63688/204382/#msg_204382
Originally posted by: szymon.kwapiszewski.com
I hit similar problem with Eclipse 3.3.0 and jboss-4.2.0.GA.
For me a workaround was to turn off the automatically publishing option in
the server tab. It caused a concurrency issues while deploying web service.
