Eclipse Community ForumsWorkbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1220499/#msg_1220499
i am developing a RAP Workbench Application and i have a problem, which only occurs in Firefox. It is working with Internet Explorer, Opera and even Epiphany ( a Linux Browser).
Sadly i am not able to reproduce it, but maybe some of you can still help me.
I am using RAP 2.2 RC1 but this problem also occurred with RAP 2.1
In one of my Workbench Perspective i have 7 views. 4 one the left side, 3 at the bottom.
Sometimes (about 50% of the time) the right views are only clickable with the right Mouse Button, meaning the Application is unusable
I have attached two screenshots showing Firebug when the view is clickable or not.
It first occurred when i was adding a fourth Combo Viewer to the "Mass" View on the left and it happened again yesterday as I added the History view (bottom left)
Another strange thing which i noticed is the following: I am using two screens at work one is my Laptop Resolution with 1366 * 768 and the other one is 1920*1080.
If I load the application on my laptop monitor, this behavior never occurs.
I have tried several things, but nothing worked, also as mentioned before this is a Firefox exclusive problem.
If you need further information please feel free to ask.
]]>Tobias P.2013-12-12T08:50:12-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1220729/#msg_1220729
sometimes, browser extensions like Firebug interfere with the
application. Could you try to test your application with Firebug disabled?
Best,
Ivan
Professional services for RAP and RCP? http://eclipsesource.com/services/rap/]]>Ivan Furnadjiev2013-12-13T10:14:10-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1220743/#msg_1220743
thanks for your reply. I restarted Firefox with all extensions/addons disabled, but the problem still occurred. ]]>Tobias P.2013-12-13T11:11:45-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1220744/#msg_1220744
is the problem reproducible for you with our online Workbench Demo [1]?
Professional services for RAP and RCP? http://eclipsesource.com/services/rap/]]>Ivan Furnadjiev2013-12-13T11:27:04-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1220748/#msg_1220748
Any other ideas?]]>Tobias P.2013-12-13T11:42:42-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1220770/#msg_1220770
without a way to reproduce the problem I can't help you much. Could you
try to create a simple project that demonstrate the issue?
Best,
Ivan
Professional services for RAP and RCP? http://eclipsesource.com/services/rap/]]>Ivan Furnadjiev2013-12-13T13:52:16-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1221267/#msg_1221267
i try to create a reproducible project]]>Tobias P.2013-12-17T09:12:04-00:00Re: Workbench not working properly with Firefox
https://www.eclipse.org/forums/index.php/mv/msg/628298/1262143/#msg_1262143
i still have no working standalone application due to time issues, but i have sorted out, what is causing the issues. The behaviour occurs when there are to much nested divs inside the first view which is shown.As a workaround i created an empty view, as the initial view and set it invisible after it gets the Focus. I hope i will have time in the next days/weeks to post a standalone example. ]]>Tobias P.2014-03-03T10:00:04-00:00
