Eclipse Community ForumsDiagram in standalone application
https://www.eclipse.org/forums/index.php/mv/msg/628033/1219634/#msg_1219634
I would like to implement a standalone application or a plugin which would be able to display UML class diagrams in one of its view. It is like putting up a static screenshot but I think it is better if I generate this diagram preview from code. Can it be done somehow using Papyrus or GMF? If so, please give me the kick-start.
Please take a look at the screenshot of similarly what I would like to do.
Tyler]]>Tyler Lee2013-12-05T06:06:00-00:00Re: Diagram in standalone application
https://www.eclipse.org/forums/index.php/mv/msg/628033/1219742/#msg_1219742
You should have a look at the code in org.eclipse.gmf.runtime.diagram.ui.OffscreenEditPartFactory
It can be used to draw a Diagram outside an Eclipse IEditoPart
