Eclipse Community ForumsWhere can I get javax.wsdl?
https://www.eclipse.org/forums/index.php/mv/msg/61757/194828/#msg_194828
I am using the org.eclipse.wst.wsdl plugin in my own plugin and I was
trying to call getInput() on a BindingInput. However, I got the error
"The type javax.wsdl.Input cannot be resolved. It is indirectly referenced
from required .class files"
Where can I get the version of this library/plugin that WTP is using?
Connie]]>Connie Lam2007-06-23T00:14:05-00:00Re: Where can I get javax.wsdl?
https://www.eclipse.org/forums/index.php/mv/msg/61757/194836/#msg_194836
Originally posted by: valentinbaciu.hotmail.com
The javax.wsdl.* classes are part of the JWSDL API. The Eclipse WSDL model
implements the JWSDL intefaces.
What version of WTP are you using? If you're using WTP 1.5.* the
javax.wsdl.* classes are in a bundle called org.wsdl4j. If you're using WTP
2.0 the javax.wsdl.* classes are in a bundle called javax.wsdl. You will
have to add this bundle as a dependency in your bundle's manifest.
"Connie" <kkconcome@yahoo.com> wrote in message
news:d9aa20094eaa47d7834a9fd06511f1a5$1@www.eclipse.org...
> Hello,
> Connie
>]]>2007-06-23T13:43:46-00:00Re: Where can I get javax.wsdl?
https://www.eclipse.org/forums/index.php/mv/msg/61757/194923/#msg_194923
>> Hello,
>> Thanks,
>> Connie
Thanks Valentin! I found it in org.wsdl4j.]]>Connie Lam2007-06-25T17:13:04-00:00
