Eclipse Community ForumsHook up for design view of XML Editor!
https://www.eclipse.org/forums/index.php/mv/msg/60351/190653/#msg_190653
Are there any hook ups or extension points for extending the Design View
of XML editor?
I want to amend the Design View of XML editor to add one more entry to the
context menu. Is such a thing possible?
Jugal Shah.]]>Jugal Shah2007-03-29T06:55:31-00:00Re: Hook up for design view of XML Editor!
https://www.eclipse.org/forums/index.php/mv/msg/60351/190671/#msg_190671
standard eclipse menu contributor extension point. Give it a try. You can
expect selected objects to be of the type org.w3c.dom.Node.
If that doesn't work open a bug to request that we respect the standard
eclipse menu extension points.
hope that helps]]>Craig Salter2007-03-29T09:26:36-00:00
