Eclipse Community ForumsSet "core.excludesfile" outside, where does it appear in Egit?
https://www.eclipse.org/forums/index.php/mv/msg/602746/1192787/#msg_1192787
David M. Karr2013-11-17T19:28:42-00:00Re: Set "core.excludesfile" outside, where does it appear in Egit?
https://www.eclipse.org/forums/index.php/mv/msg/602746/1192809/#msg_1192809
git config --global core.excludesfile <path>
You appear to have created a Git repository at the root of your HOME, or at least a .git directory, and then set the option there.
]]>R Shapiro2013-11-17T19:42:50-00:00Re: Set "core.excludesfile" outside, where does it appear in Egit?
https://www.eclipse.org/forums/index.php/mv/msg/602746/1203589/#msg_1203589
Karl Nicholas2013-11-22T18:50:55-00:00Re: Set "core.excludesfile" outside, where does it appear in Egit?
https://www.eclipse.org/forums/index.php/mv/msg/602746/1205731/#msg_1205731
Both views are part of the 'Git' perspective, but of course you can also show them in other perspectives if you like.
]]>R Shapiro2013-11-23T19:42:23-00:00Re: Set "core.excludesfile" outside, where does it appear in Egit?
https://www.eclipse.org/forums/index.php/mv/msg/602746/1207551/#msg_1207551
In other words the 'repository' display is now always identical to the the 'effective' display, and there is no way in EGit to see the local configuration.]]>R Shapiro2013-11-24T16:52:00-00:00Re: Set "core.excludesfile" outside, where does it appear in Egit?
https://www.eclipse.org/forums/index.php/mv/msg/602746/1219072/#msg_1219072
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396659]]>Matthias Sohn2013-12-01T00:29:54-00:00
