Eclipse Community ForumsPHP Project Outline is not working with remote project
https://www.eclipse.org/forums/index.php/mv/msg/5876/17585/#msg_17585
Originally posted by: muzehyun.gmail.com
windows XP
eclipse 3.3.1.1
java PDT target management
'Create Remote Project' from remote system view (some folder over sftp
connection)
And folder is created in PHP Explorer view
However when I edit php file, nothing is changed in PHP Project Outline view
And it is normally working with local files
Is there any way to solve this problem?
Thank you
Sean]]>2007-12-29T09:52:47-00:00Re: PHP Project Outline is not working with remote project
https://www.eclipse.org/forums/index.php/mv/msg/5876/17598/#msg_17598
The Outline view doesn't show anything because PHP files in a general
project don't show an outline view. The Create Remote Project action
will create a general project not a PHP project. To get this to work
you need to create the remote project differently.
You need to create a local PHP project and link folders. To link
folders right click on the project and select New -> Folder. Click on
Advanced. Select "Link to file in the file system". Change the file
system to RSE. Click Browse and find the folder you would like to link.
Sean Kim wrote:
> windows XP
> eclipse 3.3.1.1
> connection)
> Thank you
> Sean
>]]>Kevin Doyle2007-12-31T03:49:05-00:00Re: PHP Project Outline is not working with remote project
https://www.eclipse.org/forums/index.php/mv/msg/5876/571638/#msg_571638
Sean Kim wrote:
> windows XP
> eclipse 3.3.1.1
> connection)
> Thank you
> Sean
