Eclipse Community Forums[eclipse's installation on ubuntu]An error has occurred. See the log file
https://www.eclipse.org/forums/index.php/mv/msg/579977/1168719/#msg_1168719
yue xiao2013-11-03T14:13:37-00:00Re: [eclipse's installation on ubuntu]An error has occurred. See the log file
https://www.eclipse.org/forums/index.php/mv/msg/579977/1170162/#msg_1170162
yue xiao2013-11-04T12:52:59-00:00Re: [eclipse's installation on ubuntu]An error has occurred. See the log file
https://www.eclipse.org/forums/index.php/mv/msg/579977/1170450/#msg_1170450
> if i have a necessary to reinstall eclipse?
Maybe, maybe not. What have you done? What were you trying to do?]]>Russell Bateman2013-11-04T16:58:37-00:00Re: [eclipse's installation on ubuntu]An error has occurred. See the log file
https://www.eclipse.org/forums/index.php/mv/msg/579977/1171867/#msg_1171867
i installed eclipse in the linux software center,it contains openjdk,i just installed jdk to replace it.
but after replacing,it went to wrong,just like the picture i given above.
whether the jdk archive what i downloaded is incomplete?or my decompress way is not correct? ]]>yue xiao2013-11-05T14:44:12-00:00Re: [eclipse's installation on ubuntu]An error has occurred. See the log file
https://www.eclipse.org/forums/index.php/mv/msg/579977/1171868/#msg_1171868
Russell Bateman wrote on Mon, 04 November 2013 11:58
thanks to your reply.
whether the jdk archive what i downloaded is incomplete?or my decompress way is not correct? ]]>yue xiao2013-11-05T14:45:37-00:00Re: [eclipse's installation on ubuntu]An error has occurred. See the log file
https://www.eclipse.org/forums/index.php/mv/msg/579977/1171885/#msg_1171885
> way is not correct?
Never install Eclipse from any software manager. Get it only from
eclipse.org.
Since I am a Java developer, I do download a private version of a JDK
(not merely a JRE). I don't use the Java that's in use in the greater
context of the computer I'm running. I use the -vm option in eclipse.ini
to wire it up.
