Eclipse Community ForumsSelect all column cells by clicking on column header
https://www.eclipse.org/forums/index.php/mv/msg/562156/1149960/#msg_1149960
I downloaded snapshot 198. When selecting a column, the first cell gets selected.
However, in the 1.0.1 release, all the cells of the column get selected.
Has there been a change in behavior? I did not configure anything special in this respect (as far as I know). Can you give me a clue where to look for?
Kind Regards,
Arjan.]]>Arjan Kok2013-10-22T12:31:07-00:00Re: Select all column cells by clicking on column header
https://www.eclipse.org/forums/index.php/mv/msg/562156/1150001/#msg_1150001
Please correct me if I broke something. But IMHO now the behaviour is as it should. ]]>Dirk Fauth2013-10-22T13:09:11-00:00Re: Select all column cells by clicking on column header
https://www.eclipse.org/forums/index.php/mv/msg/562156/1150024/#msg_1150024
I interpreted the multiple selection flag different - I thought it meant when set to false to allow only one selected rectangle instead of to allow only one selected cell. This makes sense because a selection model can contain a list of selected rectangles.
]]>Arjan Kok2013-10-22T13:28:27-00:00Re: Select all column cells by clicking on column header
https://www.eclipse.org/forums/index.php/mv/msg/562156/1150105/#msg_1150105
Allowing multiple cells to be selected in only one rectangle doesn't make sense from a use case point of view.
As NatTable is a quite flexible framework feel free to create a new selection model that behaves as you expect it. ]]>Dirk Fauth2013-10-22T14:43:09-00:00
