Eclipse Community ForumsShow empty text elements in report
https://www.eclipse.org/forums/index.php/mv/msg/560668/1148331/#msg_1148331
I have a table with one column and two rows in its detail part. The second row contains an image while the first row contains a Text element. When the column binded to the Text element doesn't contain any text value, the Text element is removed from the layout.
I would like to keep the Text element within the layout so there will be an empty space. How can I do that?
When I use Data element, it works as I expected. But Data element can't show HTML.]]>Jan Krakora2013-10-21T12:28:46-00:00Re: Show empty text elements in report
https://www.eclipse.org/forums/index.php/mv/msg/560668/1148676/#msg_1148676
Michael Williams2013-10-21T17:16:50-00:00Re: Show empty text elements in report
https://www.eclipse.org/forums/index.php/mv/msg/560668/1148768/#msg_1148768
The only solution so far is to set a fixed height on the row of the grid containing that Text element.
I would like to find a better solution. Something like a 'showIfBlank' property. In fact that property exists, but it's ignored.
At least in matter of this meaning. ]]>Jan Krakora2013-10-21T18:36:38-00:00Re: Show empty text elements in report
https://www.eclipse.org/forums/index.php/mv/msg/560668/1162832/#msg_1162832
Jan Krakora2013-10-30T16:56:59-00:00Re: Show empty text elements in report
https://www.eclipse.org/forums/index.php/mv/msg/560668/1196948/#msg_1196948
Michael Williams2013-11-19T17:28:00-00:00
