Eclipse Community ForumsDynamic Web Project with old project structure
https://www.eclipse.org/forums/index.php/mv/msg/53809/171454/#msg_171454
Originally posted by: marx.nospam_wasko.pl
I'm using WTP 1.5RC4
I have in CVS such structure:
\application
\index.jsp
\module1
\test1.jsp
\WEB-INF
\classes
\lib - here are .jar libraries
\src - here are java sources
\web.xml - here is application web.xml file
Of course classes aren't in CVS, it's only empty directory which should
contain classes. Java sources are in \WEB-INF\src and all other jsp are
in main directory
How should I reconfigure Dynamic Web Project to match my tree?
How I create project:
new project -> checkout form CVS -> new project wizard ->Dynamic Web Project
Then i have a choice:
Dynamic Web Module 2.2/2.3 (is it JSP version or what?), anyway i leave
defaults here
Then i have:
Context root - I use defult
Content directory - I don't know what to use here, maybe "/"?
Java source directory - i write here WEB-INF/src
After this wizard Eclipse wants to switch to J2EE and downloads sources
form CVS
Next i change Java Build Path - I include all .jar as libraries and
change output folder from myproject-wtp/build/classes to
myproject-wtp/WEB-INF/classes - it works, classes compile ok and are in
ouput folder.
Now i'm starting server - it's publishing something and it starts ok, it
even see my context, but i don't see any jsp file.
I stop server and then start it again - but I can't:
"Server Tomcat v4.1 Server @ localhost failed to start"
In log:
An exception stack trace is not available.
Session data:
eclipse.buildId=I20060526-0010
java.version=1.4.2_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pl_PL
Command-line arguments: -os win32 -ws win32 -arch x86
