Eclipse Community ForumsHow to implement something like gantt chart using GMF?
https://www.eclipse.org/forums/index.php/mv/msg/53347/170147/#msg_170147
xml file which contains some attributes of the them including the start time
and time latency.The next step i have to do is to show time coordinate in
the diagram just like the one in gantt chart and make the nodes locate
themselves exactly following their timing attributes.I wonder if there is a
good way to implement this feature?Can i take advantage of the Rulers&Grid
of GMF to implement this feature?
Please give suggestion.
Thanks.]]>chaoshengshi2008-01-28T09:40:48-00:00Re: How to implement something like gantt chart using GMF?
https://www.eclipse.org/forums/index.php/mv/msg/53347/1165768/#msg_1165768
I know your post is quite old now but did you manage to do that. I need to do exactly the same thing. Otherwise did you find another solution to your problem ?
Thanks a lot.]]>boby pietri2013-11-01T14:28:54-00:00Re: How to implement something like gantt chart using GMF?
https://www.eclipse.org/forums/index.php/mv/msg/53347/1169963/#msg_1169963
what is the exact problem? Do you have a meta-model for the gant chart? Maybe a table layout could do the job for you.
Ralph]]>Ralph Gerbig2013-11-04T10:01:19-00:00Re: How to implement something like gantt chart using GMF?
https://www.eclipse.org/forums/index.php/mv/msg/53347/1173089/#msg_1173089
Yes I have an ecore metamodel.
What I am trying to do is representing the tasks dependencies of my model the same way as a usual gantt diagram meaning doing a graphical ui with "start finish/finish start..." that link tasks.
I was thinking using GMF to do that but may be I could use BIRT or SWT (I saw a gantt widget exists with SWT). However I'm not sure I can integrate BIRT and SWT with EMF which is why I was trying to do that using GMF.
Thanks. ]]>boby pietri2013-11-06T09:29:53-00:00Re: How to implement something like gantt chart using GMF?
https://www.eclipse.org/forums/index.php/mv/msg/53347/1183015/#msg_1183015
did you look at what the nebula project provides (http://www.eclipse.org/nebula/widgets/ganttchart/ganttchart.php)? You could ask in their forum what kind of data model it needs and if you can connect emf classed to it. If you cannot connect with EMF classes you could synch the model and the chart on save if you depend on EMF.
Ralph]]>Ralph Gerbig2013-11-12T15:30:17-00:00Re: How to implement something like gantt chart using GMF?
https://www.eclipse.org/forums/index.php/mv/msg/53347/1194017/#msg_1194017
Indeed it does not seem there is a data model, just widgets components.
I'll try to connect it to my existing EMF data model on load and button actions as you suggested. I'll let you know...]]>boby pietri2013-11-18T09:42:53-00:00
