Eclipse Community ForumsVariable not resolved error in Eclipse Java EE
https://www.eclipse.org/forums/index.php/mv/msg/492575/1071183/#msg_1071183
Can anyone think of why I can go out to the command line and build the 100 or so Java files, and then run the project and even set breakpoints, but I cannot watch or inspect variables.
So there's two problems:
Unable to inspect variable's values and I can no longer build from within Eclipse.
Is it due to Java updates or something.
I'm running a circa 9-20-2009 Eclipse. Is there some setting or path that might have changed. There's just something bugging my Eclipse. Should I check some path?
At least I can stop at a point - perhaps I can add a bunch of System.Print style statements for now. That will keep me going.
Any help appreciated. I've never really installed Eclipse much - it ran ok for about 4 years.
]]>John Mising name2013-07-19T14:07:28-00:00Re: Variable not resolved error in Eclipse Java EE
https://www.eclipse.org/forums/index.php/mv/msg/492575/1071663/#msg_1071663
John Mising name2013-07-20T20:40:10-00:00
