Eclipse Community Forums[ColumnReorderEvent] Possible inconsistent behavior
https://www.eclipse.org/forums/index.php/mv/msg/492194/1070655/#msg_1070655
(To see the screenshots you will have to replace the white-space with "//" since I am not allowed to post any links apparently.)
GUI
http: i.imgur.com/a6f03HP.png
(4 "normal" columns and the very first one you can not reorder at all.)
To (hopefully) reproduce the issue follow those steps:
1) Drag [Column 1] between [Column 3] and [Column 4]
GUI looks like:
http: i.imgur.com/SzAOywN.png
2) Restore the initial state and drag [Column 1] after/behind [Column 4]
GUI looks like:
http: i.imgur.com/2zgtpyk.png
So, the GUI is behaving as intended (in my opinion).
However, the ColumnReorderEvent for those two operations contains exactly the same values. So one (identical) event is replicating two different GUI states.
What do you guys think about this? Am I missing something?
]]>John Doe2013-07-18T12:05:30-00:00Re: [ColumnReorderEvent] Possible inconsistent behavior
https://www.eclipse.org/forums/index.php/mv/msg/492194/1070740/#msg_1070740
http://www.eclipse.org/forums/index.php/t/487774/
If it still exists with NatTable 1.0.1 it might be a bug.]]>Dirk Fauth2013-07-18T15:14:22-00:00Re: [ColumnReorderEvent] Possible inconsistent behavior
https://www.eclipse.org/forums/index.php/mv/msg/492194/1070765/#msg_1070765
org.eclipse.nebula.widgets.nattable.core_1.0.1.201307031725.jar
I checked the thread you linked before I posted this one. Should have mentioned it.
Could you try to reproduce the bug (if there is one) just to make sure that it is not my mistake?]]>John Doe2013-07-18T15:55:53-00:00Re: [ColumnReorderEvent] Possible inconsistent behavior
https://www.eclipse.org/forums/index.php/mv/msg/492194/1072609/#msg_1072609
Bug reported: https://bugs.eclipse.org/bugs/show_bug.cgi?id=413490]]>John Doe2013-07-23T06:28:07-00:00
