Eclipse Community Forumsmy browser widget is always causing the web kit so's to load
https://www.eclipse.org/forums/index.php/mv/msg/490182/1067800/#msg_1067800
I did the following test:
On a Redhat 6.3 machine with the following installed:
in its .ini file and the browser that I create code had SWT.MOZILLA passed in to its constructor list. With this configuration, everything comes up and I can launch the about:config page to prove that I am indeed running xulruuner. However, when I close the application it then crashes. While I was investigating that crash, I noticed that when I pmap'ed the process, I saw a:
/usr/lib64/libwebkit-1.0.so.2.17.8
in its shared library list. Further, when I uninstalled webkitgtk, my crash went away.
I have done a grep through my code and there is no where in that code where I ever instantiate a browser that is not SWT.MOZILLA.
Can anyone tell me what other things might cause the webkit libraries to load and if there is anyway to stop it?
Thanks.
-- Mark]]>Mark Fishman2013-07-10T15:55:26-00:00Re: my browser widget is always causing the web kit so's to load
https://www.eclipse.org/forums/index.php/mv/msg/490182/1069786/#msg_1069786
you're seeing an SWT bug:
1. You say that you're setting
-Dorg.eclipse.browser.DefaultType=mozilla, but your property name is
missing its "swt" segment (should be "-Dorg.eclipse.swt.br..."). Was
this just a typo in your question or do you actually have the wrong
property name in your eclipse.ini?
2. If there's another loaded plug-in that creates a Browser with style
SWT.WEBKIT then it will load webkit. Eclipse platform only creates
SWT.NONE-style Browsers, so do you have any other plug-ins that could be
doing this?
Grant
On 7/10/2013 11:55 AM, Mark Fishman wrote:
> Hello, for some strange reason my SWT browser always loads the webkit
> shared object libraries on my RH 6 machines if they are installed.
> 1. webkitgtk-1.2.6
> 2. xulrunner 10.0.5
> My SWT 3.8 application had a:
> -Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib64/xulrunner-2/
> crash went away.
> Thanks.
> -- Mark]]>Grant Gayed2013-07-16T14:55:49-00:00Re: my browser widget is always causing the web kit so's to load
https://www.eclipse.org/forums/index.php/mv/msg/490182/1070182/#msg_1070182
Thanks for replying. The missing swt in the DefaultType specification was a typo when I was writing up this topic for the forum rather than in my actual code.
As for another plugin forcing a SWT.WEBKIT, it is possible but I don't think so. I did a very simple test where I created an application which only had the plugins that get included when you click the include required plugins plus one simple plugin that I created. The one plugin had a single view with a browser widget in it. The browser widget had a SWT.NONE in its constructor and I specified the -Dorg.eclipse.swt.browser.DefaultType=mozilla -Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib64/xulrunner-2/
flags. When I did a pmap on the launched java process, I still saw /usr/lib64/libwebkit-1.0.so.2.17.8 having been loaded in. I also saw the same thing when I ran it passing SWT.MOZILLA to the browser.
It should be noted though that I did not get a crash when I closed my test application.
