Eclipse Community ForumsUse emf.edit.ui in pure E4 app
https://www.eclipse.org/forums/index.php/mv/msg/489576/1065619/#msg_1065619
Thanks!]]>Erdal Karaca2013-06-26T17:23:09-00:00Re: Use emf.edit.ui in pure E4 app
https://www.eclipse.org/forums/index.php/mv/msg/489576/1065621/#msg_1065621
Erdal Karaca wrote on Wed, 26 June 2013 19:23
Does anyone know how to use the emf.edit.ui plugin (AdapterFactory[Label/Content]Provider for use with the generated edit code) in a pure E4 app?
Thanks!
]]>Erdal Karaca2013-06-26T17:43:50-00:00Re: Use emf.edit.ui in pure E4 app
https://www.eclipse.org/forums/index.php/mv/msg/489576/1065626/#msg_1065626
You could perhaps check this out: https://github.com/dzonekl/e4mf
there is a e4 version of emf.edit.ui. It has some limitations and
compilation errors (As 3.x dependencies are removed), but it works.
