Eclipse Community ForumsChanging the default build command in the Builder settings
https://www.eclipse.org/forums/index.php/mv/msg/488828/1063348/#msg_1063348
Since I've built my new dev box, I've had to go back and remember to manually set -j7 to all of my project build settings. Is there a way that I can streamline this by simply changing the default build command?
I've looked through the help section but I cannot find anything as it appears to be written more from the higher level/user perspective. I've ctrl-F'd through the entire installation directory searching for a string that might be alterable to include this but to know avail.
Using Juno.
Thank you for any ideas.]]>Michael S2013-06-13T02:07:32-00:00
