Eclipse Community ForumsLeft shortcuts after uninstalling the plugin
https://www.eclipse.org/forums/index.php/mv/msg/486229/1053918/#msg_1053918
i have installed the jubula plugin for eclipse 4.2 x64 yesterday (via market place) and removed it again today (also via marketplace). unfortunately there are some jubula shortcuts left which interfere with the std. shortcuts and are not changeable/deleteable.
For example "F3" (usually "open declaration") now opens a small yellow popup where i am asked which action i want to trigger ("open declaration" or "open s&pecification").
Is there any trick how to get rid of those shortcuts?
thx, br klemensl]]>klemens loschy2013-05-08T07:17:59-00:00Re: Left shortcuts after uninstalling the plugin
https://www.eclipse.org/forums/index.php/mv/msg/486229/1058493/#msg_1058493
Thanks for the information! I wasn't aware of this up until now - could you open a ticket in the Jubula Bugzilla? https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Jubula
I'm also not aware of anything you can do to get rid of them (but then I'm not the best person to ask) - if you ask again on the ticket, then someone may be able to make a suggestion.
Thanks!
Alex]]>Alexandra Schladebeck2013-05-14T11:12:07-00:00Re: Left shortcuts after uninstalling the plugin
https://www.eclipse.org/forums/index.php/mv/msg/486229/1058785/#msg_1058785
klemens loschy2013-05-15T06:02:02-00:00Re: Left shortcuts after uninstalling the plugin
https://www.eclipse.org/forums/index.php/mv/msg/486229/1058807/#msg_1058807
klemens loschy2013-05-15T07:59:50-00:00Re: Left shortcuts after uninstalling the plugin
https://www.eclipse.org/forums/index.php/mv/msg/486229/1058819/#msg_1058819
Thanks for putting in the ticket [1] and for posting your workaround. I'm going to add the workaround to the ticket as well.
