Eclipse Community ForumsProblem with papyrusDiagram extension point on Papyrus 0.9.2
https://www.eclipse.org/forums/index.php/mv/msg/483289/1049815/#msg_1049815
I encoutered a bug with the papyrusDiagram extension point, only on Papyrus v0.9.2 (that works fine on Papyrus 0.9.0).
I use the extension point to register new language and new diagram. However, the factory class referenced in the extension point element "editorDiagram" is never called. Instead, the factory class of the extended uml diagram (I suspect that the useCase uml diagram factory class is called rather than mine, because, in the diagram creation command, I reference the UseCaseDiagramEditPart notation).
