org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://com.ourCustomer.dat/modeltransformation/1.0' not found. (file:/c:/otx-test/self_adjustment_of_mixture_formation.0.modeltransformation, 2, 251)
-- @atlcompiler emftvm module transformate2otx; create OUT: otx, time: otxDateTime, diag: otxDiagCom, data: otxDiagDataBrowsing, event: otxEvent, flash: otxFlash, hmi: otxHmi, i18n: otxI18n, job: otxJob, log: otxLogging, math: otxMath, measure: otxMeasure, quant: otxQuantities, string: otxStringUtil from IN: transformate;
Cannot set EMFTVM!CodeBlock::nested to latestHandler:ATL!NavigationOrAttributeCallExp for 326c52e3:EMFTVM!CodeBlock: containment references cannot span across models org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.ClassCastException at abstract rule BindingStat@applier#77(platform:/plugin/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLtoEMFTVM.atl#[824:34-824:54]) Local variables: [__trace__: TRACE!TraceLink = 739274bc:TRACE!TraceLink, s: ATL!BindingStat = 42e9ac30:ATL!BindingStat, cb: EMFTVM!CodeBlock = 326c52e3:EMFTVM!CodeBlock, ln: EMFTVM!LineNumber = 7042d019:EMFTVM!LineNumber, invokeCb: EMFTVM!InvokeCb = 3256462:EMFTVM!InvokeCb, invokeCb2: EMFTVM!InvokeCb = be15f8b:EMFTVM!InvokeCb, set: EMFTVM!FieldInstruction = 7947a4c4:EMFTVM!Set] at static EMFTVM!ExecEnv::main() : Object(platform:/plugin/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLtoEMFTVM.atl) Local variables: [] at org.eclipse.m2m.atl.emftvm.impl.CodeBlockImpl.internalExecute(CodeBlockImpl.java:989) at org.eclipse.m2m.atl.emftvm.impl.CodeBlockImpl.execute(CodeBlockImpl.java:728) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl$WithApplierWithoutPostApplyCbState.applyFor(RuleImpl.java:1204) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl.applyFor(RuleImpl.java:2229) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl$IsNotAbstractState.apply(RuleImpl.java:981) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl.apply(RuleImpl.java:2199) at org.eclipse.m2m.atl.emftvm.impl.ExecEnvImpl.matchAllSingle(ExecEnvImpl.java:2180) at org.eclipse.m2m.atl.emftvm.impl.ExecEnvImpl.run(ExecEnvImpl.java:2028) at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:189) at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:138) at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:107) at org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlCompiler.java:156) at org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlCompiler.java:125) at org.eclipse.m2m.atl.adt.AtlBuildVisitor.visit(AtlBuildVisitor.java:115) at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:126) at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:85) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:95) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:52) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:124) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:108) at org.eclipse.m2m.atl.adt.AtlBuilder.fullBuild(AtlBuilder.java:68) at org.eclipse.m2m.atl.adt.AtlBuilder$1.run(AtlBuilder.java:49) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326) at org.eclipse.m2m.atl.adt.AtlBuilder.run(AtlBuilder.java:108) at org.eclipse.m2m.atl.adt.AtlBuilder.build(AtlBuilder.java:52) at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239) at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295) at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351) at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374) at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143) at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) Caused by: java.lang.ClassCastException Cannot set EMFTVM!CodeBlock::nested to latestHandler:ATL!NavigationOrAttributeCallExp for 4b5432a8:EMFTVM!CodeBlock: containment references cannot span across models org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.ClassCastException at abstract rule BindingStat@applier#77(platform:/plugin/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLtoEMFTVM.atl#[824:34-824:54]) Local variables: [__trace__: TRACE!TraceLink = 2d591708:TRACE!TraceLink, s: ATL!BindingStat = 64bc7e34:ATL!BindingStat, cb: EMFTVM!CodeBlock = 4b5432a8:EMFTVM!CodeBlock, ln: EMFTVM!LineNumber = d35dd4e:EMFTVM!LineNumber, invokeCb: EMFTVM!InvokeCb = 601659f1:EMFTVM!InvokeCb, invokeCb2: EMFTVM!InvokeCb = 5b6b0e7f:EMFTVM!InvokeCb, set: EMFTVM!FieldInstruction = 5184e2bc:EMFTVM!Set] at static EMFTVM!ExecEnv::main() : Object(platform:/plugin/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLtoEMFTVM.atl) Local variables: [] at org.eclipse.m2m.atl.emftvm.impl.CodeBlockImpl.internalExecute(CodeBlockImpl.java:989) at org.eclipse.m2m.atl.emftvm.impl.CodeBlockImpl.execute(CodeBlockImpl.java:728) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl$WithApplierWithoutPostApplyCbState.applyFor(RuleImpl.java:1204) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl.applyFor(RuleImpl.java:2229) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl$IsNotAbstractState.apply(RuleImpl.java:981) at org.eclipse.m2m.atl.emftvm.impl.RuleImpl.apply(RuleImpl.java:2199) at org.eclipse.m2m.atl.emftvm.impl.ExecEnvImpl.matchAllSingle(ExecEnvImpl.java:2180) at org.eclipse.m2m.atl.emftvm.impl.ExecEnvImpl.run(ExecEnvImpl.java:2028) at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:189) at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:138) at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:107) at org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlCompiler.java:156) at org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlCompiler.java:125) at org.eclipse.m2m.atl.adt.AtlBuildVisitor.visit(AtlBuildVisitor.java:115) at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:126) at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:85) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86) at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:95) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:52) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:124) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:108) at org.eclipse.m2m.atl.adt.AtlBuilder.fullBuild(AtlBuilder.java:68) at org.eclipse.m2m.atl.adt.AtlBuilder$1.run(AtlBuilder.java:49) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326) at org.eclipse.m2m.atl.adt.AtlBuilder.run(AtlBuilder.java:108) at org.eclipse.m2m.atl.adt.AtlBuilder.build(AtlBuilder.java:52) at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239) at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295) at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351) at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374) at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143) at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53) Caused by: java.lang.ClassCastException
do { object.property.property <- thisModule.property; -- ^^^ something goes wrong here }
do { object.property.property <- (thisModule.property); }
