Eclipse Community Forums[Xtend] performance and memory usage
https://www.eclipse.org/forums/index.php/mv/msg/474705/1039653/#msg_1039653
Just a technical question, I observed bad performances (a couple of seconds hanging up and massive heap space usages) when editing an xtend class (+/- 1K LOC and +/- 30 methods), especially when I use auto-completion.
Is it a known problem or due to the version I'm using (Xtend 2.3.1). Should I upgrade?
Thanks in advance,
Fabian]]>Fabian G.2013-04-12T12:02:18-00:00Re: [Xtend] performance and memory usage
https://www.eclipse.org/forums/index.php/mv/msg/474705/1041572/#msg_1041572
generally speaking: Yes, you should upgrade if you only use Xtend. The
performance was improved. If you have a Xtext language that uses Xbase
expressions, there'll be some effort to upgrade to 2.4 so you might want
to hold you horses and wait for Kepler, which will improve the APIs for
Xbase clients.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 12.04.13 14:02, schrieb Fabian G.:
> auto-completion.
> Should I upgrade?
> Thanks in advance,
> Cheers,
> Fabian]]>Sebastian Zarnekow2013-04-15T09:04:17-00:00
