Eclipse Community ForumsPDF export problem
https://www.eclipse.org/forums/index.php/mv/msg/462116/1022956/#msg_1022956
when i export a report with a url like this: http://localhost:8082/birt4/run?__format=PDF&__report=\report_detail.rptdesign
i receive in response not a streaming af a file pdf, but receeive an html file (even if the file opens correctly and if i save it with my PDF Viewer and opening it I see it with the correct header); how can i get direct streaming pdf format?
]]>Mimmo Rossi2013-03-22T22:19:32-00:00[NO PROBLEM] Re: PDF export problem
https://www.eclipse.org/forums/index.php/mv/msg/462116/1023447/#msg_1023447
Mimmo Rossi wrote on Fri, 22 March 2013 18:19
Hi All,
Hi All,
this problem isn't a problem!!!I receive an html response ONLY if a report goes in error, so it's ok!
My apologies for the false alarm!
]]>Mimmo Rossi2013-03-24T08:30:05-00:00
