Eclipse Community Forums[RESOLVED] Empty "Post-commit hook failure notification" dialog is always raised
https://www.eclipse.org/forums/index.php/mv/msg/457964/1016504/#msg_1016504
After a quick look to the code, it seems to be a bug in the code of subversive. In the class ShowPostCommitErrorsOperation, there is the following check before opening the message dialog:
But, lokking a operation providing postCommitErrors, they always initialize the error array at the beginning, and then fill it if needed. So the above check always get an array (empty in there is no problem) instead of null, and so always displays the error message...
]]>Guillaume P.2013-03-06T17:04:39-00:00Re: Empty "Post-commit hook failure notification" dialog is always raised
https://www.eclipse.org/forums/index.php/mv/msg/457964/1016514/#msg_1016514
Guillaume P.2013-03-06T17:54:04-00:00Re: Empty "Post-commit hook failure notification" dialog is always raised
https://www.eclipse.org/forums/index.php/mv/msg/457964/1016755/#msg_1016755
https://bugs.eclipse.org/bugs/show_bug.cgi?id=402491. It is already fixed in the latest update.]]>Konrad Windszus2013-03-07T15:22:28-00:00Re: Empty "Post-commit hook failure notification" dialog is always raised
https://www.eclipse.org/forums/index.php/mv/msg/457964/1018149/#msg_1018149
Guillaume P.2013-03-13T09:08:34-00:00
