Eclipse Community ForumsAdding elements to AnyAttribute
https://www.eclipse.org/forums/index.php/mv/msg/453623/1009613/#msg_1009613
I have derived an Ecore model from a XML schema. The schema has an element which can contain arbitrary attributes, which is expressed via the anyAttribute option. It is no problem to read these attributes with EMF. But I would also like to add attributes to the anyAttribute field of the implementation class. However, there are are lots of references and values stored in the features representing the attributes. Is there an easy way to add new elements?
