Eclipse Community ForumsMark like words in Teradata plugin?
https://www.eclipse.org/forums/index.php/mv/msg/452263/1006065/#msg_1006065
Select date from calendartable
union all
select date-2 from calendartable
When I highlight "date" it should highlight the other date that shows up in my code. It seems like there is an option to do this in a Java file but I was not able to use it while writing SQL in my teradata plugin.
Thanks for the help!]]>Donald Lay2013-01-29T17:15:25-00:00Re: Mark like words in Teradata plugin?
https://www.eclipse.org/forums/index.php/mv/msg/452263/1007170/#msg_1007170
Donald Lay2013-02-04T16:56:06-00:00
