Eclipse Community Forumscolumn initialization order in CTableTree
https://www.eclipse.org/forums/index.php/mv/msg/4506/13577/#msg_13577
Originally posted by: alnospammajor.noboxspamspoon.com
in my usage scenario, the viewer in column x depends on the viewer in
column y (both in the same row). so i need to makes sure the the
initialization of the viewer in column y is completed before column x
needs its values.
what's the best way to achieve this?
al]]>2006-10-06T17:26:51-00:00Re: column initialization order in CTableTree
https://www.eclipse.org/forums/index.php/mv/msg/4506/13601/#msg_13601
the "obvious" answer is to subclass CTableTreeViewer and override
doUpdateItem. this seems too heavy handed. is there a better option?
> needs its values.
> al]]>2006-10-07T21:26:21-00:00Re: column initialization order in CTableTree
https://www.eclipse.org/forums/index.php/mv/msg/4506/566311/#msg_566311
> needs its values.
> al]]>Al Major2006-10-07T21:26:21-00:00Re: column initialization order in CTableTree
https://www.eclipse.org/forums/index.php/mv/msg/4506/13621/#msg_13621
as expected, this does the trick. but i'm not too happy with it.
>> needs its values.
>> al]]>2006-10-08T00:59:41-00:00Re: column initialization order in CTableTree
https://www.eclipse.org/forums/index.php/mv/msg/4506/566339/#msg_566339
>> needs its values.
>> al]]>Al Major2006-10-08T00:59:41-00:00
