SEVERE: The web application [\sampleApp] created a ThreadLocal with key of type [org.eclipse.emf.ecore.impl.EClassImpl$1] (value [org.eclipse.emf.ecore.impl.EClassImpl$1@1ed9228]) and a value of type [java.util.HashSet] (value [[]]) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
Dec 21, 2012 11:33:47 AM org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
SEVERE: The web application [\sampleApp] created a ThreadLocal with key of type [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil.CharArrayThreadLocal] (value [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil$CharArrayThreadLocal@166c9d1]) and a value of type [char[]] (value [[C@14bc24a]) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
SEVERE: The web application [\sampleApp] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@c0a9c3]) and a value of type [java.util.WeakHashMap] (value [{class javax.xml.bind.annotation.W3CDomHandler=java.lang.ref.WeakReference@c96cad}]) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
SEVERE: The web application [\sampleApp] created a ThreadLocal with key of type [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil.CharArrayThreadLocal] (value [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil$CharArrayThreadLocal@166c9d1]) and a value of type [char[]] (value [[C@1fdecee]) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
