Eclipse Community ForumsSuddenly VE stopped working
https://www.eclipse.org/forums/index.php/mv/msg/44218/143493/#msg_143493
Originally posted by: cachirro.netcabo.pt
i was using VE with no problems, but don't know why, suddenly stopped working.
When i start Eclipse, it appears "setup java visual editor" and it doesn't moves from the 75%, and in the design appears "loading".
What is the problem and how can i fix it?
Thanks for helping.]]>2008-01-15T01:00:28-00:00Re: Suddenly VE stopped working
https://www.eclipse.org/forums/index.php/mv/msg/44218/143503/#msg_143503
damn...
i teste eclipse 3.3, then eclipse 3.4, then easyeclipse 1.2, all they have VE working, except when i try my damn code wich was working.
all i remember doing was using the source menu and do some code cleaning and auto adjustments.
can someone help me trace what is causing VE to not work?
Thanks.]]>2008-01-15T03:02:07-00:00Re: Suddenly VE stopped working
https://www.eclipse.org/forums/index.php/mv/msg/44218/616925/#msg_616925
