Eclipse Community ForumsRegarding Graphiti 0.10.0 MileStone Fixes
https://www.eclipse.org/forums/index.php/mv/msg/441324/989986/#msg_989986
Are the Graphiti 0.10.0 MileStone Fixes avalaible with Juno SR2 release (which is planned on February 22, 2013).
Do we have to wait for Kepler release?
Advance thanks for your reply.
Raghava Rao]]>Raghava Rao2012-12-10T10:46:21-00:00Re: Regarding Graphiti 0.10.0 MileStone Fixes
https://www.eclipse.org/forums/index.php/mv/msg/441324/990044/#msg_990044
the Graphiti release 0.10.0 (and the milestones towards it) will only go
into the Eclipse Kepler release, not into Juno SR2. You could either consume
the milestone releases directly or in case you would like to see a bugfix in
Juno SR2 simply ask for that fix to be downported (best to do that directly
in the bug). Some already were downported (check for the Juno SRx entry in
the whiteboard field in the bugzilla) others are planned (check the Juno
flag). In case a bugfix is easy to downport, we are open to do so on
request; note that this will not apply for enhancements as Juno SR1 and SR2
are pure bugfix releases.
