Eclipse Community ForumsRegister Profile
https://www.eclipse.org/forums/index.php/mv/msg/440463/986804/#msg_986804
I have extended MARTE profile in a way that i have added some attributes. The produced profile is in uml format and there exist 2 files, the profile and the MARTE library that supports it. I would like to register this profile and to be available in the menu of the apply registered profile (like the native profiles are). I have spent couple of hours, but i did not find any solution that works for Eclipse Helios which i am using. The Papyrus plugin installed is the 0.7.3. I have tried the solution that is referred here (www.papyrusuml.org/scripts/home/publigen/content/templates/show.asp?P=133&L=EN&ITEMID=26)
but there is missing the com.cea.papyrus.extensionpoints... which is part of the standalone version.
Thanks in advance for your help.
Kostas]]>Kostas Triantafyllidis2012-11-21T17:11:44-00:00Re: Register Profile
https://www.eclipse.org/forums/index.php/mv/msg/440463/986824/#msg_986824
Simon Schwichtenberg2012-11-21T19:09:37-00:00Re: Register Profile
https://www.eclipse.org/forums/index.php/mv/msg/440463/986883/#msg_986883
The website papyrusuml.org referes to the older versions of Papyrus (Until il became an Eclipse Project).
You may find the extension point you're looking for in org.eclipse.papyrus.extensionpoints (Helios/Indigo) or org.eclipse.papyrus.uml.extensionpoints (Juno/Kepler)
