In order to get remote agent working, you will have to=20
1. install the Agent Controller on the remote box=20
2. setup the environment variables on the remote box=20
Set TPTP_AC_HOME=3D<<Agent Controller Home>>=20
Set =
JAVA_PROFILER_HOME=3D%TPTP_AC_HOME%\plugins\org.eclipse.tptp .javaprofiler=
=20
Set PATH=3D%JAVA_PROFILER_HOME%;%PATH%;%TPTP_AC_HOME%\bin=20
Set PATH=3D%PATH%;%JAVA_HOME%\bin=20
3. start the target process with =
-agentlib:JPIBootLoader=3DJPIAgent:server=3Denabled;..... vm argument.=20
I have update the documentation of the Agent Controller and please refer =
to the section 'Inovcation of the Java Profiler from the Command Line'=20 http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platfo=
rm.agentcontroller/src-native-new/packaging_md/windows/getti ng_started.ht=
ml?root=3DTPTP_Project&view=3Dco=20
Let me know if you see any needs for update and changes.=20
It would be better if we continue this discussion in the newsgroup =
(news://news.eclipse.org/eclipse.tptp) such that the user community can =
track better, I have posted our discussion there for you to follow. This =
mailing list is aimed for TPTP Trace and Profiling Tools Project =
developer discussion.=20
Thanks I appreciate the effort. Please let me know when you have more =
detail and I will look it over and comment. As you know for the dll =
issue I was taking a guess on what to do since there was no reference on =
how the tool finds those by Environment variables.
My question to you is to get remote agent working on a test box with =
Weblogic what do I have to have installed to get that agent working in =
server=3Denabled mode? For my windows box where I have both eclipse and =
WLS 10.3 installed I had to point my "PATH" environment variable to the =
directory where the dll AgentBase was located. On a box where WLS =
running do I have to have eclipse installed or is there a Agent install =
or zip with just the needed libraries?
For some reason yesterday I did not get any execution analysis info and =
today it started working without any effort on my part. What I do is go =
to Eclipse and do the following:
1. From Menu button go to Profile Configurations Window
2. On left hand sidebar select Attach to Agent "New Configuration" item =
from tree (note the leaf "New Configuration" was created previously)
3. In main content pane select the "Agents" tab (note it was highlighted =
in red)
4. On the Available agents tab there should be displayed text Java =
Profiling- JRE 1.5 or newer ... Check the check box for that tree branch =
and the "Execution Time Analysis" leaf will also be checked.
5. Select "Apply" button then the "Profile" button
6. The Eclipse view "Profiling and L..." will be shown (already selected =
to begin with) and the "Profile Monitor" tab will be shown in a state =
where a new Monitoring profile item is displayed in the "<monitoring>" =
state.
7. If I double click the execution analysis I will eventually get the =
profile timing analysis in the "Execution Analysis" tab.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV>
<P><FONT face=3DArial size=3D2>This a repost of the mailing list =
discussion on=20
profiling WLS.</FONT></P>
<P><FONT face=3DArial=20
size=3D2> ------------------------------------------------------------ ----=
----------------------</FONT></P>
<P><FONT face=3DArial size=3D2>Hi Tony, <BR><BR>In order to get remote =
agent=20
working, you will have to <BR>1. install the Agent Controller on the =
remote box=20
<BR>2. setup the environment variables on the remote box <BR>Set=20
TPTP_AC_HOME=3D<<Agent Controller Home>> <BR>Set=20
<BR>Set=20
PATH=3D%JAVA_PROFILER_HOME%;%PATH%;%TPTP_AC_HOME%\bin <BR>Set=20
PATH=3D%PATH%;%JAVA_HOME%\bin <BR>3. start the target process with=20
-agentlib:JPIBootLoader=3DJPIAgent:server=3Denabled;..... vm argument. =
<BR><BR>I=20
to the=20
section 'Inovcation of the Java Profiler from the Command Line' =
<BR></FONT><A=20
href=3D" http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tpt=
p.platform.agentcontroller/src-native-new/packaging_md/windo ws/getting_st=
arted.html?root=3DTPTP_Project&view=3Dco"><FONT=20
face=3DArial=20
size=3D2> http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tp=
tp.platform.agentcontroller/src-native-new/packaging_md/wind ows/getting_s=
tarted.html?root=3DTPTP_Project&view=3Dco</FONT></A ><FONT=20
face=3DArial size=3D2> <BR><BR>Let me know if you see any needs for =
update and=20
changes. <BR>It would be better if we continue this discussion in the =
newsgroup=20
(</FONT><A href=3D"news://news.eclipse.org/eclipse.tptp"><FONT =
face=3DArial=20
size=3D2>news://news.eclipse.org/eclipse.tptp</FONT></A><FONT =
face=3DArial size=3D2>)=20
such that the user community can track better, I have posted our =
discussion=20
there for you to follow. This mailing list is aimed for TPTP Trace and =
Profiling=20
Tools Project developer discussion. <BR></FONT></P>
<P><FONT face=3DArial size=3D2>Eugene</FONT></P>
<P><FONT face=3DArial size=3D2>Hi Eugene,<BR><BR>Thanks I appreciate the =
effort.=20
Please let me know when you have more detail and I will look it over and =
comment. As you know for the dll issue I was taking a guess on what to =
do since=20
there was no reference on how the tool finds those by Environment=20
variables.<BR><BR>My question to you is to get remote agent working on a =
test=20
box with Weblogic what do I have to have installed to get that agent =
working in=20
WLS 10.3=20
installed I had to point my "PATH" environment variable to the directory =
where=20
the dll AgentBase was located. On a box where WLS running do I have to =
have=20
eclipse installed or is there a Agent install or zip with just the =
needed=20
libraries?<BR><BR>For some reason yesterday I did not get any execution =
analysis=20
info and today it started working without any effort on my part. What I =
do is go=20
to Eclipse and do the following:<BR><BR>1. From Menu button go to =
Profile=20
Configurations Window<BR>2. On left hand sidebar select Attach to Agent =
"New=20
Configuration" item from tree (note the leaf "New Configuration" was =
created=20
previously)<BR>3. In main content pane select the "Agents" tab (note it =
was=20
highlighted in red)<BR>4. On the Available agents tab there should be =
displayed=20
text Java Profiling- JRE 1.5 or newer ... Check the check box for that =
tree=20
branch and the "Execution Time Analysis" leaf will also be =
checked.<BR>5. Select=20
"Apply" button then the "Profile" button<BR>6. The Eclipse view =
"Profiling and=20
L..." will be shown (already selected to begin with) and the "Profile =
Monitor"=20
tab will be shown in a state where a new Monitoring profile item is =
displayed in=20
the "<monitoring>" state.<BR>7. If I double click the execution =
analysis I=20
will eventually get the profile timing analysis in the "Execution =
Analysis"=20
tab.<BR></FONT></P><FONT face=3DArial size=3D2><FONT face=3DHelv =
size=3D1><FONT=20
face=3DHelv size=3D1>
<P>Tony Anecito </P></FONT></FONT></FONT></DIV></BODY></HTML>
After running SetConfig.bat I get an error for AC 4.5.2 that the config =
file has an error yet no detail about what the problem is. I am using =
1.6.0_13 under windows XP SP2. My config file is as follows. Does the =
environment variables have to be already setup because of the "replace" =
property in the config file? I am following the setup instructions from:
Set =
=20
I have update the documentation of the Agent Controller and please =
refer to the section 'Inovcation of the Java Profiler from the Command =
Line'=20
= http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platfo=
For some reason yesterday I did not get any execution analysis info =
and today it started working without any effort on my part. What I do is =
go to Eclipse and do the following:
2. On left hand sidebar select Attach to Agent "New Configuration" =
item from tree (note the leaf "New Configuration" was created =
previously)
3. In main content pane select the "Agents" tab (note it was =
highlighted in red)
6. The Eclipse view "Profiling and L..." will be shown (already =
selected to begin with) and the "Profile Monitor" tab will be shown in a =
state where a new Monitoring profile item is displayed in the =
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DCourier size=3D2><FONT face=3DCourier size=3D2>
<P><FONT face=3DArial>[REPOST FRPM THE MAILING LIST]</FONT><BR></P>
<P>Hi All,<BR><BR>After running SetConfig.bat I get an error for AC =
4.5.2 that=20
the config file has an error yet no detail about what the problem is. I =
am using=20
1.6.0_13 under windows XP SP2. My config file is as follows. Does the=20
property=20
in the config file? I am following the setup instructions=20
from:<BR><BR> http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips =
e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getti=
ng_started.html?root=3DTPTP_Project&view=3Dco#Java_1 5 <BR><BR><BR>Than=
ks,<BR>-Tony<BR><BR><?xml=20
version=3D"1.0"=20
encoding=3D"UTF-8"?><BR><AgentControllerConfiguration> <BR><Ag=
entControllerEnvironment=20
configuration=3D"default"><BR><Variable name=3D"JAVA_PATH" =
position=3D"replace"=20
value=3D"c:\java\jdk1.6.0_13\bin\java.exe"/><BR><Variable=20
name=3D"RASERVER_HOME" position=3D"replace"=20
value=3D"C:\TPTP452AgentController"/><BR><Variable =
name=3D"TPTP_AC_HOME"=20
position=3D"replace" value=3D"%RASERVER_HOME%"/><BR><Variable=20
name=3D"TPTP_AC_CONFIG_HOME" position=3D"replace"=20
value=3D"%RASERVER_HOME%\config"/><BR><Variable =
name=3D"PLUGINS_HOME"=20
value=3D"C:\TPTP452AgentController\plugins"/><BR><Variable =
name=3D"PATH"=20
position=3D"prepend" value=3D"%RASERVER_HOME%\bin"/><BR><Variable=20
name=3D"SYS_TEMP_DIR" position=3D"replace" =
value=3D"%TEMP%"/><BR><Variable=20
name=3D"LOCAL_AGENT_TEMP_DIR" position=3D"replace"=20
value=3D"%SYS_TEMP_DIR%"/><BR><Variable=20
name=3D"CLASSPATH_ORG_APACHE_COMMONS_LOGGING" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.apache.commons.logging _1.0=
..4.v20080605-1930.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.core.commands_ 3.4.=
0.I20080509-2000.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.core.runtime_3 .4.0=
..v20080512.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.equinox.common _3.4=
..0.v20080421-2006.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_OSGI" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.osgi_3.4.3.R34 x_v2=
0081215-1030.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_EMF_COMMON" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.emf.common_2.2 .2.v=
200710030400.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_EMF_ECORE" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.emf.ecore_2.2. 4.v2=
name=3D"CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.emf.ecore.xmi_ 2.2.=
4.v200710030400.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_JFACE" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.jface_3.4.2.M2 0090=
107-0800.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_SWT" position=3D"append"=20
value=3D"C:\TPTP452AgentController\plugins\swt.jar"/> <BR><Variable =
name=3D"CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.eclipse.tptp.platform. mode=
ls_4.5.2.v200901290906\tptp-models.jar"/><BR><Variable=20
name=3D"CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS_HIERARCHY " =
ls.hierarchy_4.5.1.v200902180100\tptp-models-hierarchy.jar"/> <BR><V=
ariable=20
name=3D"CLASSPATH_ORG_JUNIT" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\org.junit_3.8.2.v20080602- 1318=
\junit.jar"/><BR><Variable=20
name=3D"CLASSPATH_COM_IBM_ICU" position=3D"append"=20
value=3D" C:\TPTP452AgentController\plugins\com.ibm.icu_3.8.1.v2008053 0.ja=
name=3D"CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING" =
value=3D"%CLASSPATH_ORG_APACHE_COMMONS_LOGGING%"/><BR ><Variable=20
name=3D"CLASSPATH" position=3D"append"=20
0081215-1030.jar"/><BR></AgentControllerEnvironment> <BR><Appl=
icationAliases><BR><Application=20
configuration=3D"default" executable=3D"java.exe" =
location=3D"%SYS_TEMP_DIR%"=20
path=3D"%JAVA_PATH%"><BR><Variable name=3D"CLASSPATH" =
value=3D"%CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON%"/><BR ><Variable =
name=3D"PATH"=20
position=3D"prepend"=20
value=3D"%RASERVER_HOME%\bin"/><BR></Application> <BR></Applic=
ationAliases><BR><Plugin=20
path=3D"%PLUGINS_HOME%"/><BR><Agent=20
path=3D"%TPTP_AC_HOME%\agents"/><BR><Jvm=20
location=3D"C:\Java\jdk1.6.0_13\jre\bin\server\jvm.dll"/> <BR><Loggi=
ng=20
directory=3D"%TPTP_AC_CONFIG_HOME%" format=3D"CBE"=20
level=3D"INFORMATION"/><BR><ProcessController>%TPTP_AC_HOME%\bin=
\tptpProcessController.exe</ProcessController> <BR><Connection=20
name=3D"Dev"><BR><TransportLayer loadlib=3D"socketTL"=20
type=3D"TPTP_SOCKET"><BR><Configuration> <BR><Port>10006<=
;/Port><BR> <SecurityEnabled>false</SecurityEnabled > <BR><=
;/Configuration><BR> <CommandExtractor>tptpCmdExtr</CommandE xt=
ractor><BR></TransportLayer><BR><TransportLayer=20
loadlib=3D"namedPipeTL"=20
type=3D"TPTP_LOG"><BR><Configuration> <BR><PipeName>acmaste=
rlog</PipeName><BR></Configuration> <BR><CommandExtractor&g=
t;tptpCmdExtr</CommandExtractor><BR></TransportLayer> <BR><=
TransportLayer=20
type=3D"TPTP_NAMEDPIPE"><BR><Configuration> <BR><PipeName>a=
cmaster</PipeName><BR></Configuration> <BR><CommandExtracto=
r>tptpCmdExtr</CommandExtractor><BR></TransportLayer> <BR>&=
lt;TransportLayer=20
loadlib=3D"sharedMemTL"=20
type=3D"TPTP_SHAREDMEM"><BR><Configuration> <BR><MemName>ac=
buffer</MemName><BR></Configuration> <BR><CommandExtractor&=
gt;tptpCmdExtr</CommandExtractor><BR></TransportLayer> <BR><=
;TransportLayer=20
loadlib=3D"tptpCCTL"=20
type=3D"TPTP_CCTL"><BR><Configuration> <BR><Port>10002</=
Port><BR> <SecuredPort>10003</SecuredPort> <BR><FilePort&=
gt;10005</FilePort><BR><IsDataMultiplexed>false</IsDataMul=
tiplexed><BR> <ProcessPolling>true</ProcessPolling&am p;gt; <BR><=
Version>4.4.1</Version><BR><SecurityEnabled>false</Secu=
rityEnabled><BR><Hosts=20
configuration=3D"default"><BR><Allow=20
type=3D"LOCAL"/><BR></Hosts><BR></Configuration> <BR><Co=
mmandExtractor>tptpCmdExtr</CommandExtractor&a mp;gt; <BR></TransportL=
loadlib=3D"tptpACTL"=20
type=3D"TPTP_ACTL"><BR><Configuration/> <BR><CommandExtractor&=
;/Connection><BR> <PeerConnectionTransport>TPTP_CCTL</Pee rConn=
ectionTransport><BR></AgentControllerConfiguration> <BR><BR><FONT=
=20
face=3DArial>Tony</FONT></P></FONT></FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Eugene Chan" <<A=20
href=3D"mailto:ewchan@ca.ibm.com">ewchan@ca.ibm.com</A>> wrote in =
message <A=20
href=3D"news:gs2bc8$ufq$1@build.eclipse.org">news:gs2bc8$ufq$1@build.ecli=
pse.org</A>...</DIV>
<DIV>
discussion on=20
agent=20
remote=20
box <BR>2. setup the environment variables on the remote box <BR>Set=20
=20
<BR>Set PATH=3D%JAVA_PROFILER_HOME%;%PATH%;%TPTP_AC_HOME%\bin <BR>Set=20
<BR><BR>I=20
to the=20
<BR></FONT><A=20
face=3DArial=20
update and=20
changes. <BR>It would be better if we continue this discussion in the=20
newsgroup (</FONT><A =
href=3D"news://news.eclipse.org/eclipse.tptp"><FONT=20
face=3DArial =
size=3D2>news://news.eclipse.org/eclipse.tptp</FONT></A><FONT=20
face=3DArial size=3D2>) such that the user community can track better, =
I have=20
posted our discussion there for you to follow. This mailing list is =
aimed for=20
TPTP Trace and Profiling Tools Project developer discussion. =
<BR></FONT></P>
<P><FONT face=3DArial size=3D2>Hi Eugene,<BR><BR>Thanks I appreciate =
the effort.=20
Please let me know when you have more detail and I will look it over =
and=20
do=20
since there was no reference on how the tool finds those by =
Environment=20
variables.<BR><BR>My question to you is to get remote agent working on =
a test=20
working=20
in server=3Denabled mode? For my windows box where I have both eclipse =
and WLS=20
directory=20
where the dll AgentBase was located. On a box where WLS running do I =
have to=20
have eclipse installed or is there a Agent install or zip with just =
the needed=20
libraries?<BR><BR>For some reason yesterday I did not get any =
execution=20
analysis info and today it started working without any effort on my =
part. What=20
I do is go to Eclipse and do the following:<BR><BR>1. From Menu button =
go to=20
Profile Configurations Window<BR>2. On left hand sidebar select Attach =
to=20
Agent "New Configuration" item from tree (note the leaf "New =
Configuration"=20
was created previously)<BR>3. In main content pane select the "Agents" =
tab=20
(note it was highlighted in red)<BR>4. On the Available agents tab =
there=20
should be displayed text Java Profiling- JRE 1.5 or newer ... Check =
the check=20
box for that tree branch and the "Execution Time Analysis" leaf will =
also be=20
checked.<BR>5. Select "Apply" button then the "Profile" button<BR>6. =
The=20
Eclipse view "Profiling and L..." will be shown (already selected to =
begin=20
with) and the "Profile Monitor" tab will be shown in a state where a =
new=20
state.<BR>7.=20
profile=20
timing analysis in the "Execution Analysis" tab.<BR></FONT></P><FONT=20
face=3DArial size=3D2><FONT face=3DHelv size=3D1><FONT face=3DHelv =
size=3D1>
<P>Tony Anecito =
</P></FONT></FONT></FONT></DIV></BLOCKQUOTE></BODY></HTML >
Hi Tony,
What kind of error did you get? The config file seems fine to me.
You do not need to have any environment varilables setup before running =
setconfig.bat. Could you try remove the files under AC/config folder and =
rerun the setconfig.bat again. I assume you are using a standalone Agent =
Controller.
After running SetConfig.bat I get an error for AC 4.5.2 that the =
config file has an error yet no detail about what the problem is. I am =
using 1.6.0_13 under windows XP SP2. My config file is as follows. Does =
the environment variables have to be already setup because of the =
"replace" property in the config file? I am following the setup =
instructions from:
Set =
=20
Line'=20
Thanks I appreciate the effort. Please let me know when you have =
more detail and I will look it over and comment. As you know for the dll =
previously)
highlighted in red)
7. If I double click the execution analysis I will eventually get =
the profile timing analysis in the "Execution Analysis" tab.
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Tony,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>What kind of error did you get? The =
config file=20
seems fine to me.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>You do not need to have any environment =
varilables=20
setup before running setconfig.bat. Could you try remove the files under =
AC/config folder and rerun the setconfig.bat again. I assume you are =
using a=20
standalone Agent Controller.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Eugene</FONT></DIV>
message <A=20
href=3D"news:gs2i4k$l8e$1@build.eclipse.org">news:gs2i4k$l8e$1@build.ecli=
4.5.2 that=20
the config file has an error yet no detail about what the problem is. =
I am=20
using 1.6.0_13 under windows XP SP2. My config file is as follows. =
Does the=20
"replace"=20
property in the config file? I am following the setup instructions=20
version=3D"1.0"=20
configuration=3D"default"><BR><Variable name=3D"JAVA_PATH"=20
name=3D"PATH"=20
position=3D"prepend" =
=20
<BR>Set PATH=3D%JAVA_PROFILER_HOME%;%PATH%;%TPTP_AC_HOME%\bin =
<BR>Set=20
-agentlib:JPIBootLoader=3DJPIAgent:server=3Denabled;..... vm =
argument. <BR><BR>I=20
refer to=20
<BR></FONT><A=20
face=3DArial=20
update and=20
changes. <BR>It would be better if we continue this discussion in =
the=20
face=3DArial =
face=3DArial size=3D2>) such that the user community can track =
better, I have=20
aimed=20
for TPTP Trace and Profiling Tools Project developer discussion.=20
<BR></FONT></P>
the effort.=20
and=20
comment. As you know for the dll issue I was taking a guess on what =
to do=20
Environment=20
variables.<BR><BR>My question to you is to get remote agent working =
on a=20
test box with Weblogic what do I have to have installed to get that =
agent=20
working in server=3Denabled mode? For my windows box where I have =
both eclipse=20
and WLS 10.3 installed I had to point my "PATH" environment variable =
to the=20
running do=20
I have to have eclipse installed or is there a Agent install or zip =
with=20
just the needed libraries?<BR><BR>For some reason yesterday I did =
not get=20
any execution analysis info and today it started working without any =
effort=20
on my part. What I do is go to Eclipse and do the =
following:<BR><BR>1. From=20
Menu button go to Profile Configurations Window<BR>2. On left hand =
sidebar=20
select Attach to Agent "New Configuration" item from tree (note the =
leaf=20
"New Configuration" was created previously)<BR>3. In main content =
pane=20
select the "Agents" tab (note it was highlighted in red)<BR>4. On =
the=20
Available agents tab there should be displayed text Java Profiling- =
JRE 1.5=20
or newer ... Check the check box for that tree branch and the =
"Execution=20
Time Analysis" leaf will also be checked.<BR>5. Select "Apply" =
button then=20
the "Profile" button<BR>6. The Eclipse view "Profiling and L..." =
will be=20
shown (already selected to begin with) and the "Profile Monitor" tab =
will be=20
shown in a state where a new Monitoring profile item is displayed in =
the=20
analysis I=20
Analysis"=20
size=3D1><FONT=20
<P>Tony Anecito=20
</P></FONT></FONT></FONT></DIV></BLOCKQUOTE></BLOCKQUOTE ></BODY></HTML>
