Eclipse Community Forums.exe don´t work in other pc
https://www.eclipse.org/forums/index.php/mv/msg/430750/975251/#msg_975251
I´ve created with eclipse juno (64) with MinGW (32) a .exe
but this executable does not work in other pc without MinGW (.dll).
How can eclipse create a .exe that does not need .dll???
Thank you.]]>Elena Perez2012-11-07T18:34:34-00:00Re: .exe don´t work in other pc
https://www.eclipse.org/forums/index.php/mv/msg/430750/978860/#msg_978860
you could use this linker options to build a statically linked version (but this will increase the size of the executable!):
-static-libgcc -static-libstdc++
Add them under Project -> Properties -> C/C++Build -> Settings -> Linker -> Miscellaneous
