<rm:searchPath name="server.local.platform">
<rm:provider readerType="p2" componentTypes="osgi.bundle,eclipse.feature" mutable="false" source="false">
<rm:uri format="{0}">
<bc:propertyRef key="p2.platform.dir"/>
</rm:uri>
</rm:provider>
</rm:searchPath>
Contains: [0003] : An error occurred copying file \\temp\platform\plugins\com.mydependency.ui_3.3.0.jar.
java.io.FileNotFoundException: \\temp\platform\plugins\com.mydependency.ui_3.3.0.jar (The network path was not found)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.copyFileToStream(SimpleArtifactRepository.java:641)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:666)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:590)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:723)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:287)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:267)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:208)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:138)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:707)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:778)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch(DownloadManager.java:112)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:100)
at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:101)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:241)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:98)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.buckminster.core.materializer.P2Materializer.materialize(P2Materializer.java:319)
at org.eclipse.buckminster.core.materializer.MaterializerJob.run(MaterializerJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
