Eclipse Community ForumsInstall problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/12601/#msg_12601
and osee seemed to be just the sort of thing I was looking for.
I am relatively new to the eclipse world and can't seem to get osee
running.
I am using Windows XP.
I have downloaded postgresql and installed successfully.
I added the osee user and created the database as per these instructions:
!ENTRY org.eclipse.osgi 4 0 2009-04-17 20:12:59.390
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.osee.framework.application.server.DbInit" could not be found
in the registry. The applications available are:
org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error,
org.eclipse.equinox.p2.artifact.repository.mirrorApplication ,
org.eclipse.equinox.p2.director.app.application,
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator,
org.eclipse.equinox.p2.metadata.repository.mirrorApplication ,
org.eclipse.equinox.p2.reconciler.application,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer, org.eclipse.ant.ui.antRunner,
org.eclipse.birt.report.debug.core.ReportDebugger,
org.eclipse.birt.report.engine.ReportExecutor,
org.eclipse.datatools.connectivity.console.profile.StorageFi leEditor,
org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger,
org.eclipse.emf.codegen.ecore.Generator,
org.eclipse.emf.importer.ecore.Ecore2GenModel,
org.eclipse.emf.importer.java.Java2GenModel,
org.eclipse.emf.importer.rose.Rose2GenModel,
org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter,
org.eclipse.pde.build.Build,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.legacytestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.junit.runtime.coretestapplicationnonmain,
org.eclipse.wst.jsdt.core.JavaCodeFormatter,
org.eclipse.wst.server.preview.preview,
org.eclipse.osee.framework.database.configClient,
org.eclipse.osee.framework.database.availableDbTasks,
org.eclipse.osee.framework.jini.JiniLookup,
org.eclipse.osee.framework.messaging.event.skynet.EventServi ce.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)]]>Rob2009-04-18T02:53:22-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/12648/#msg_12648
http://osee.microdoc.com/node/2 and I am just a new user like yourself.
However, I failed to initialise the database because I didn't start the
server first before running oseeDbInitLocalc.exe. I'm wondering whether
your problem is something similar and you need to get the local OSEE
database server running first before you try the init.
Just a thought,
Mark]]>Mark D-B2009-04-20T16:29:55-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572580/#msg_572580
Just a thought,
https://www.eclipse.org/forums/index.php/mv/msg/4217/12690/#msg_12690
oseeAppServerRemotc.exe program and the runServer-PgSqlLocalAll.sh script.
Also tried java updates, switching to earlier version of postgresql
(8.2.13).
Did all the create user, create database, create schema stuff on the
database for osee. Was careful about the uppercasee 'OSEE' database name.
Have tried stopping and restarting the database.
Have tried this on my work machine and my machine at home.
Eclipse starts fine.
Postgreql starts fine.
Running OseeLocal, or oseePostgresMicro results in JVM termination exit
code -1
I think it might be memory - I have only 1.5 G on this machine but only
713K free.
I tried on a third machine with more memory and it appears to work.
Thanks for help. Your success at least told me that there is something
wrong here.
Rob]]>Rob2009-04-20T20:30:29-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572623/#msg_572623
(8.2.13).
code -1
713K free.
wrong here.
https://www.eclipse.org/forums/index.php/mv/msg/4217/12712/#msg_12712
Follow instructions at http://osee.microdoc.com/node/2
I have updated the documentation page at http://www.eclipse.org/osee/documentation/index.php to show the launch step.]]>Donald Dunne2009-04-20T20:44:34-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572711/#msg_572711
When I run the script runServer-PgSqlLocalAll I get a bunch of messages
printed out on the server.
The log is shown below. Spams something about Tagging on Server Startup
was not run and Server lookup table not initialized - not sure if this is
bad or not, but I think it likely is.
I have messed with firewall settings, even turning the firewall off.
Mon Apr 20 20:45:15 MDT 2009
org.eclipse.osee.framework.core.server.CoreServerActivator
INFO
org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore
deregisterWithDb (63)
INFO
registerWithDb (80)
Mon Apr 20 20:45:18 MDT 2009
org.eclipse.osee.framework.search.engine.internal.SearchEngi neTagger
INFO org.eclipse.osee.framework.search.engine.internal.StartUpRun nable
run (45)
Tagging on Server Startup was not run.]]>Rob2009-04-21T03:00:04-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/12779/#msg_12779
INFO
INFO
registerWithDb (80)
run (45)
https://www.eclipse.org/forums/index.php/mv/msg/4217/572725/#msg_572725
Database Initialization Instructions:
1. Database has been installed: check
2. Database server is running: I have confirmed the database server is
running (pgAdmin III): OSEE database with osee owner.
3. A file system path has been selected for binary data storage: I do not
know how to select this path but I am assuming the default is sufficient
4. An application server is running:
a)Within the app_server_0.7.0-2009-02-19_08_49 directory in a command
console:
osgi> 21-Apr-2009 8:32:38 AM org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
21-Apr-2009 8:32:39 AM org.mortbay.util.Container start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@1d009b4
INFO: Started HttpContext[/,/]
21-Apr-2009 8:32:39 AM org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:8089
INFO: Started org.mortbay.http.HttpServer@544ec1
Adding: org.eclipse.osee.framework.core.server.internal.ServerDataba seProvider @39443f
Registered servlet '/GET.ARTIFACT'
Registered servlet '/osee/artifact'
Registered servlet '/osee/branch'
Registered servlet '/osee/branch/exchange'
Registered servlet '/osee/install/info'
Registered servlet '/osee/resource'
Registered servlet '/osee/search'
Registered servlet '/osee/search/tagger'
Registered servlet '/osee/server/lookup'
Registered servlet '/osee/session'
Registered servlet '/osee/client/loopback'
Tue Apr 21 08:32:45 ADT 2009
INFO org.eclipse.osee.framework.core.server.internal.ServerTaskSc heduler
addServerTask (41)
Adding task: Clean up join tables
INFO org.eclipse.osee.framework.core.server.OseeServerProperties
getOseeApplicationServerData (54)
Application Server Data: [C:\Documents and Settings\trent]
org.eclipse.osee.framework.db.connection.internal.InternalAc tivator
INFO org.eclipse.osee.framework.db.connection.OseeConnectionPool
getConnection (71)
getConnection - jdbc:postgresql://localhost:5432/OSEE - connection pool
size [1]
INFO
INFO
registerWithDb (80)
Tue Apr 21 08:32:48 ADT 2009
run (45)
osgi> Tue Apr 21 08:42:45 ADT 2009
WARNING
org.eclipse.osee.framework.core.server.internal.task.CleanJo inTablesServerTask
run (59)
org.postgresql.util.PSQLException: ERROR: relation "osee_join_artifact"
does not exist
org.eclipse.osee.framework.db.connection.exception.OseeDataS toreException:
does not
exist
at
org.eclipse.osee.framework.db.connection.ConnectionHandler.r unPreparedUpdate(ConnectionHandler.java:100)
at
org.eclipse.osee.framework.db.connection.ConnectionHandler.r unPreparedUpdate(ConnectionHandler.java:57)
at
org.eclipse.osee.framework.core.server.internal.task.CleanJo inTablesServerTask.run(CleanJoinTablesServerTask.java:56)
at
java.util.concurrent.Executors$RunnableAdapter.call(Executor s.java:441)
at
java.util.concurrent.FutureTask$Sync.innerRunAndReset(Future Task.java:317)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java: 150)
at
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFu tureTask.access$101(ScheduledThreadPoolExecutor.java:98)
at
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFu tureTask.runPeriodic(ScheduledThreadPoolExecutor.java:181)
at
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFu tureTask.run(ScheduledThreadPoolExecutor.java:205)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.postgresql.util.PSQLException: ERROR: relation
"osee_join_artifact" does not exist
at
org.postgresql.core.v3.QueryExecutorImpl.receiveErrorRespons e(QueryExecutorImpl.java:1608)
at
org.postgresql.core.v3.QueryExecutorImpl.processResults(Quer yExecutorImpl.java:1343)
at
org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecut orImpl.java:194)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.execute(Abstract Jdbc2Statement.java:451)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags (AbstractJdbc2Statement.java:350)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(Ab stractJdbc2Statement.java:304)
at
org.eclipse.osee.framework.db.connection.ConnectionHandler.r unPreparedUpdate(ConnectionHandler.java:98)
... 11 more
The stack trace shows up after the application server launch due to what?
and when? unsure.
Database initialization attempt generates the same error as Rob]]>Trent Johnson2009-04-21T11:51:12-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/12799/#msg_12799
console:
addServerTask (41)
getConnection (71)
size [1]
INFO
INFO
registerWithDb (80)
run (45)
WARNING
run (59)
does not exist
does not
exist
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 11 more
and when? unsure.
https://www.eclipse.org/forums/index.php/mv/msg/4217/12819/#msg_12819
are they in and why/when do you use them?
Note I am having the exact same problems as Rob and I am trying to
determine the solution.
Trent]]>Trent Johnson2009-04-21T11:55:51-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572739/#msg_572739
https://www.eclipse.org/forums/index.php/mv/msg/4217/13440/#msg_13440
The quick answer is that the messages you see indicate that the server
started correctly.
The first word in the log messages indicates the severity (i.e. INFO).
The messages you are noticing about Tagging and Server lookup table not
initialized are of type INFO and do not represent a problem. The several
lines such that start with "Registered servlet" indicate the successful
start-up of various OSEE services.
The server is up and running and the next step is to initialize the
database. The message about the Server lookup table not initialized is
due to the database tables not yet existing (they are created during the
database initialization).
I see there is another post about the database initialization, so I will
reply to that one with more information.
Ryan]]>Ryan D. Brooks2009-04-21T15:02:38-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572830/#msg_572830
started correctly.
https://www.eclipse.org/forums/index.php/mv/msg/4217/13476/#msg_13476
Not meaning to shang-hai Rob's problems but I have been investigating the
same issue.
I can confirm your statements that the application server is fine - I
confirmed by using the tutorial db init command "oseeDbInitLocalc.exe" and
then continuing with the tutorial via both the tutorial instance of
eclipse plus my own instance of eclipse with all of the dependencies
installed and the command line parameters of "-vmargs -Xmx512m
-Dosee.application.server=http://localhost:8089
-Dosee.authentication.protocol=demo".
I then repeated the problem of not being able to run the original DbInit
command "C:\eclipse>eclipse -nosplash -application
org.eclipse.osee.framework.application.server.DbInit -console -vmargs
-XX:MaxPermSize=256m -Xmx512m -Dosgi.compatibility.bootdelegation=true
-Dequinox.ds.debug=true -Dorg.osgi.service.http.port=8089
-Dosee.local.application.server=true
-Dosee.db.connection.id=postgresqlLocalhost" with the result of the
originally reported errors.
Any thoughts?
Trent]]>Trent Johnson2009-04-21T16:37:27-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572878/#msg_572878
same issue.
Any thoughts?
https://www.eclipse.org/forums/index.php/mv/msg/4217/13497/#msg_13497
(A fellow that works with me that has eclipse experience arrived at the
following solution.)
Install postgresql as per the instructions.
Run the the osee server (i.e. the runServer-PgSqlLocalAll.sh)
run oseeDbInitLocalc.exe
run oseeLocalc.exe
DO NOT run oseePostgresMicro.exe - if you do, this is what causes the
problem, and you must shutdown the osee server (i.e. exit the
If you try to run oseeLocal or oseeDbInitLocalc after the running of
oseePostgresMicroc without first exiting runServer-PgSqlLocalAll, then the
problem does not get resolved.
Anyways, this has got me up and running that will allow me to give this a
whirl.
Thanks all for the input and help.
Rob]]>Rob2009-04-21T23:21:06-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/572909/#msg_572909
run oseeLocalc.exe
whirl.
https://www.eclipse.org/forums/index.php/mv/msg/4217/572930/#msg_572930
> run oseeLocalc.exe
I agree that these steps will provide a running eclipse instance with
which you can learn the osee capabilities and actions available.
However it doesn't get me a clean initialized database that I can use for
my own purposes using my own installation of eclipse/plugins/and tools.
Trent]]>Trent Johnson2009-04-22T03:27:29-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/13518/#msg_13518
> run oseeLocalc.exe
https://www.eclipse.org/forums/index.php/mv/msg/4217/572981/#msg_572981
initializing our own database , according to my understanding all it does
is pre-initialize database by connecting to external server (May be the
university example Don explained in his screen cast)...what you can do in
documentation (http://osee.microdoc.com/node/2) for OSEE client launch
options follow step 2 "Local Application Server with Local PostgreSql
Database" instead of step 1 "Pre-initialized Database".
Anyways i was also looking at oseePostgresMicro configuration settings and
i thought there could be two possibilities why this error is occuring:
1) There is "http://osee.microdoc.com:8089/" parameter passed to
application server. I am more thinking there is something wrong there, may
be they(developers) removed data from the 8089 port. In the installation
documentation, they say
"Launch the OSEE Eclipse client using <install dir>\oseePostgresMicroc.exe
to connect to the Microdoc repository. You must have access to port 5432
to be able to connect"
So i am guessing if we change the port number from 8089 to 5432 in
configuration settings it should work...
2) In the version 0.7.0 the
"org.eclipse.osee.framework.application.server.DbInit" is not registering
(or) doesn't exist. I am not sure where this file should be, i have
checked appserver plugins and it doesn't exist there and i think it should
be replaced with "org.eclipse.osee.demo.db.connection_0.4.0.200902191228"
or something else
Anyways i would try the case 1 by myself soon and can tell you what
happened...
I just thought of sharing this...
I would really appreciate if developers can answer this connection to
pre-initialized database problem. Also in the documentation
(http://osee.microdoc.com/node/2) you have indicated run populate demo
action, but i am missing it, can you provide me some detail guidance where
that demo action is?]]>Venkat Mantripragada2009-04-22T16:35:41-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/13557/#msg_13557
or something else
happened...
https://www.eclipse.org/forums/index.php/mv/msg/4217/13646/#msg_13646
> I don't think not executing oseePostgresMicroc.exe will stop us from
> "Launch the OSEE Eclipse client using <install dir>oseePostgresMicroc.exe
> or something else
> happened...
There you go, if you replace the db_init with the below statement, it
works, I have successfully populate my OSEE 0.7 with the john hopkins demo
data...
eclipsec -application org.eclipse.osee.framework.database.configClient
-vmargs -Xmx256m -Dosee.log.default=INFO
-Dosee.authentication.protocol=trustAll -Dosee.prompt.on.db.init=false
-Dosee.choice.on.db.init="OSEE Demo Database"]]>Venkat Mantripragada2009-04-24T20:42:48-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/573080/#msg_573080
> or something else
> happened...
data...
https://www.eclipse.org/forums/index.php/mv/msg/4217/13688/#msg_13688
instructions in some shape or form because microdocs doesn't match eclipse
and what is in the brief from eclipsecon2009 is a little different as well.
Following your steps when I run the oseedbinitlocalc.exe file eclipse
throws an error log which is:
!ENTRY org.eclipse.osgi 4 0 2009-04-27 09:48:37.578
!STACK 1
org.eclipse.osee.framework.core.exception.OseeAuthentication Exception: http://localhost:8089/osee/session?operation=create
at
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.internalAcquireSession(InternalClientSessio nManager.java:215)
at
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.authenticate(InternalClientSessionManager.j ava:111)
at
org.eclipse.osee.framework.core.client.ClientSessionManager. authenticate(ClientSessionManager.java:98)
at
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation.execute(DatabaseInitializationOperation.j ava:68)
at
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation.executeConfigureFromJvmProperties(Databas eInitializationOperation.java:294)
at
org.eclipse.osee.framework.database.ConfigDatabase.start(Con figDatabase.java:32)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
at
at
at
at
at
Caused by: java.io.IOException: Error during POST
[http://localhost:8089/osee/session?operation=create] - status code: [500]
at
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:116)
at
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.internalAcquireSession(InternalClientSessio nManager.java:210)
... 17 more
Caused by: java.lang.Exception: HTTP/1.1 500 Internal Server Error
at
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:108)
... 18 more]]>SR Mising name2009-04-27T13:53:57-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/573125/#msg_573125
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 17 more
at
https://www.eclipse.org/forums/index.php/mv/msg/4217/573187/#msg_573187
>> run oseeLocalc.exe
!ENTRY org.eclipse.osgi 4 0 2009-04-28 14:49:38.096
!STACK 1
in the registry.
The only way to solve the problem is getting the file through Update
manager in eclipse, then only eclipse will register. But, where is the
file? which one should i update to get this file?
If anybody knows the solution, please provide it. An updated documentation
is greatly appreciated.
Please note: The documentation for running a demo database, screen casts,
wiki is very good, i got understanding of the tool by using demo data. But
when i want to start piloting this good tool in our company, there is no
clear documentation on where to start for a clean installation.
Thank you.]]>Venkat Mantripragada2009-04-28T21:11:53-00:00Re: Install problems
https://www.eclipse.org/forums/index.php/mv/msg/4217/13750/#msg_13750
>> run oseeLocalc.exe
!STACK 1
in the registry.
