Eclipse Community Forumsfailed to redefine 1 classes. JVMTI Error: 62
https://www.eclipse.org/forums/index.php/mv/msg/41347/134373/#msg_134373
Originally posted by: jay.tenmilesquare.com
I am having a problem similar to others that I have seen on this mailing
list. The last few lines of the log file are below this email. I can
send 2 full compressed log files from 2 distinct runs if necessary.
My configuration is as follows:
1. Operating system version: Windows XP SP2
2. Architecture: IA32
3. TPTP Version: TPTP-4.5
4. Agent Controller version - 4.5
5. Java version SUN JDK 1.6.0_07
Jay
Informative 08/18/08 16:39:46 672 3
CJVMTIInterface [GetLineNumberTable] user-supplied buffer is too short.
table size = 2, buffer size = 1, buffer actual size = 2)
table size = 19, buffer size = 1, buffer actual size = 19)
Informative 08/18/08 16:39:46 2276 0
CDataManager Class 'com/company/package/webapp/search/TreePanel' has
wrong instrumentation. Queuing class for redefinition
Informative 08/18/08 16:39:46 2276 3
CClassRedefThread Received request to to redefine 1 classes.
isBlocking = 0
Informative 08/18/08 16:39:46 2640 3 CGAdaptor
Class java/lang/VerifyError was not instrumented because all its
methods were excluded
Informative 08/18/08 16:39:46 2640 0
CDataManager Class 'java/lang/VerifyError' has wrong instrumentation,
but will not be redefined due to user-defined filters or an internal reason
CJVMTIInterface RedefineClasses: failed to redefine 1 classes. JVMTI
Error: 62
Error 08/18/08 16:39:46 2640 0
CJavaInstrumentorManager RedefineClasses failed. Instrumented
classes may be in inconsistent state]]>2008-08-18T17:26:39-00:00Re: failed to redefine 1 classes. JVMTI Error: 62
https://www.eclipse.org/forums/index.php/mv/msg/41347/134482/#msg_134482
Please post the complete log files.
Can you also describe your usage scenario? What type of application are
you profiling? Which data collector do you use?
