Eclipse Community Forumsre-generate captured text
https://www.eclipse.org/forums/index.php/mv/msg/411010/953437/#msg_953437
Example:
Grammar:
Given the ArgSpec instance (which is possibly a complex type with properties etc) I would like to simply generate the string "5*PI", without manual processing all the fields of the ArgSpec instance
I hope it's clear
Thank you
B]]>Bruce L.2012-10-22T08:40:12-00:00Re: re-generate captured text
https://www.eclipse.org/forums/index.php/mv/msg/411010/953446/#msg_953446
if i get you write you have a parsed eobject in your hand and want to access the text that was parsed.
you get access to the node model through the NodeModelUtil class.
~Christian
]]>Christian Dietrich2012-10-22T08:52:41-00:00Re: re-generate captured text
https://www.eclipse.org/forums/index.php/mv/msg/411010/953519/#msg_953519
So far, I found these
