Eclipse Community ForumsRefactoring
https://www.eclipse.org/forums/index.php/mv/msg/3867/11507/#msg_11507
while trying to import from XMI, I had an object for which I had to choose
the artefact. I choose Entity, but after loading, I got the message Key
not found and I realized it should have being a Datatype artefact.
How can I change from an artefact to another?
I looked into Refactor, but there is just rename and move.
Marc]]>Marc FLAUW2008-07-09T15:23:45-00:00Re: Refactoring
https://www.eclipse.org/forums/index.php/mv/msg/3867/11543/#msg_11543
There used to be an additional entry in the refactor menu to do that, but it
was mostly broken, so we took it out as part of the open-source move.
The initial design was wrong in that you'd be able to refactor from anything
to anything whereas some refactor don't make sense (association to entity
makes no sense).
So, what we need is "refactoring options that make sense based on the
starting point". For example:
- Entity<->Datatype
- Association<->Dependency
- Association<->AssociationClass
- Datatype<->Query<->UpdateProc<->Event
Bug 221443 covers the refactoring from Association to Association Class.
And should be extended to address the other cases.
> Dear all,
> Marc
>]]>Eric Dillon2008-07-09T15:39:03-00:00Re: Refactoring
https://www.eclipse.org/forums/index.php/mv/msg/3867/563531/#msg_563531
makes no sense).
- Entity<->Datatype
> Dear all,
> Marc
https://www.eclipse.org/forums/index.php/mv/msg/3867/11580/#msg_11580
Change the top level tag from
@tigerstripe.managedEntity to @tigerstripe.datatype.
Save it and open it with the Tigerstripe Explorer, and make a tiny change
(description e.g.) to force it to reparse/save it.
This is a hack... But in the meantime it may help :-).
> Hi Marc,
> makes no sense).
> - Entity<->Datatype
> Does that make sense to you?
> Eric
> On 7/9/08 8:23 AM, in article
> 32fc6d642c0af7145037a4b5f3bfa794$1@www.eclipse.org, "Marc FLAUW"
> <marc.flauw@hp.com> wrote:
>> Dear all,
>> Thanks,
>> Marc
>]]>Eric Dillon2008-07-09T15:44:47-00:00Re: Refactoring
https://www.eclipse.org/forums/index.php/mv/msg/3867/563555/#msg_563555
> Hi Marc,
> makes no sense).
> - Entity<->Datatype
> Eric
>> Dear all,
>> Thanks,
>> Marc
https://www.eclipse.org/forums/index.php/mv/msg/3867/11616/#msg_11616
Thanks for the response.
I know the hack. I used it already, but today, I am just playing with the
SID model so I don't have the time to hack each file.
I understand the concern around refactoring, but I had this exact need
with the model import: I don't know exactly what X is, so let's make it an
entity and then Tigerstripe complain about no key after the import is
completed and you realize that it should have been a datatype.
So this situation is likely to happen. I agree we need to restrict what we
can refactor to, as some combinations don't make sense.
Do you want me to open an enhancement bug?
Marc]]>Marc FLAUW2008-07-10T10:36:05-00:00Re: Refactoring
https://www.eclipse.org/forums/index.php/mv/msg/3867/563579/#msg_563579
https://www.eclipse.org/forums/index.php/mv/msg/3867/11651/#msg_11651
Eric
> Eric,
> Marc
>]]>Eric Dillon2008-07-10T14:07:30-00:00Re: Refactoring
https://www.eclipse.org/forums/index.php/mv/msg/3867/563605/#msg_563605
Eric
> Eric,
> Marc
