Eclipse Community ForumsUsage of CallOperationAction
https://www.eclipse.org/forums/index.php/mv/msg/380385/918692/#msg_918692
I am trying to simulate a model with activities that call operations of other objects (or event of the same object) using the "Call Operation Action" but this doesn't seem to work, contrary to "Call Behaviour Action". Has anybody got a simple example model that uses CallOperationAction and can be animated?
For simulation I'm using the "Papyrus Animator" of Papyrus V0.8.2 (as part of Topcased 5.2.0) running on Eclipse 3.7.2.
Thanks in advance,
Ivan
]]>Ivan MacDonald2012-09-21T08:57:05-00:00Re: Usage of CallOperationAction
https://www.eclipse.org/forums/index.php/mv/msg/380385/918704/#msg_918704
did you post a message on TOPCASED users mailing list? As simulation is a TOPCASED component you would certainly have better chances to get answers from that channel.
raphaƫl]]>Raphael Faudou2012-09-21T09:04:49-00:00Re: Usage of CallOperationAction
https://www.eclipse.org/forums/index.php/mv/msg/380385/918705/#msg_918705
]]>Ivan MacDonald2012-09-21T09:07:49-00:00Re: Usage of CallOperationAction
https://www.eclipse.org/forums/index.php/mv/msg/380385/940619/#msg_940619
So currently callOperation is not supported in TOPCASED simulation component.]]>Raphael Faudou2012-10-11T20:29:24-00:00
