Eclipse Community ForumsEclipse and FFTW
https://www.eclipse.org/forums/index.php/mv/msg/379762/917991/#msg_917991
As a first thing I have to say that I'm relatively new to Eclipse and programming world, so I'm a kind of newbie
I don't know if here inside there's someone familiar with FFTW and FFTW++, useful and excellent libraries able to perform DFTs.
I'm trying to merge this library with another one that actually is working (was working ). I think I have a problem with the compiler. As I was writing my code, using another IDE and typing the commands from bash I realized that some mp options were needed, so I've updated my version of gcc from 4.2.1 (that is the basic Xcode version for MacOS) to 4.7. I've compiled my simple program and it worked, compiling it with g++. I have used macports to install the new version of gcc and I have used one of its options (sudo port select --set gcc mp-gcc47) to set it as gcc default command, in place of the 4.2 version, so I can type and compile from bash.
Now I'm trying to include this library in a project on Eclipse that compiles with gcc, and I see that it uses the version 4.2.1. Does somebody know how to change it into the 4.7 version? Do you think that this could solve the problem?
If I try to modify the compiler form the project->properties->etc. from gcc to g++ FFTW (apparently) works but the other project doesn't anymore (of course). Any suggestion? Is there any possibility to compile FFTW with gcc?
Is anyone here that made an eclipse project with FFTW inside?
Thank you very much to all of you ]]>Alessandro Romeo2012-09-20T16:23:00-00:00
