Eclipse Community Forums3.4.0 of webtools shows as available for 3.7.2 Eclipse, but has dependencies on 3.8.
https://www.eclipse.org/forums/index.php/mv/msg/375321/911554/#msg_911554
If I "check for updates" in 3.7.2 of Eclipse, I see the latest version
of webtools as being available for update. But if I select anything, it
tells me it can't install them because of dependency issues, and when I
examine what those are, it is dependencies on Eclipse 3.8 jars.
I will NOT upgrade to 3.8/4.2 until someone gives me my themes back.
The amount of productivity I would lose trying to wrap my head around
someone ELSE'S idea of where tabs should go on a window, etc. is simply
not a viable option.
So please at least mark the latest webtools things so that I no longer
see them as a possible update.]]>2012-09-11T21:05:03-00:00Re: 3.4.0 of webtools shows as available for 3.7.2 Eclipse, but has dependencies on 3.8.
https://www.eclipse.org/forums/index.php/mv/msg/375321/912193/#msg_912193
Nitin Dahyabhai2012-09-13T05:49:05-00:00Re: 3.4.0 of webtools shows as available for 3.7.2 Eclipse, but has dependencies on 3.8.
https://www.eclipse.org/forums/index.php/mv/msg/375321/921854/#msg_921854
> Which update sites are known to this installation? A fresh unzip of
> Indigo SR2 (which has WTP 3.3.2) doesn't suggest WTP 3.4 as an update.
> You can find this out from your Available Software Sites preference page
> in Eclipse.
Interesting...
Some other plugin added the Juno repo for me. :-( I'll have to track
that down and stomp on it.
I removed the 2 Juno entries, and no longer see WTP 3.4 as an update
possibility.
Thanks for the pointer.]]>2012-09-24T13:42:56-00:00
