Eclipse Community Forumseclipse classic Unexpected end of ZLIB input stream
https://www.eclipse.org/forums/index.php/mv/msg/372401/907195/#msg_907195
Today I downloaded the latest version of eclipse classic 4.2:
eclipse-SDK-4.2-win32-x86_64.zip
eclipse-SDK-4.2-win32.zip
My operating system: Windows 7 64, Windows XP (2 different PCs)
I tried to unzip the files using:
1. Windows 7 built in extract tool
2. WinRar
3. Java command (i.e. jar xf c:\apps\eclipse-SDK-4.2-win32-x86_64.zip)
In all 3 way I failed, Using Windows 7 built in extract tool I got the following error:
The compressed (Zipped) folder is empty
Using WinRar command I got the following error:
! C:\apps\eclipse-SDK-4.2-win32-x86_64.zip: The archive is either in unknown format or damaged
Using the java command I got the following error:
c:\APS\jdk1.6.0_24\bin>jar xf c:\apps\eclipse-SDK-4.2-win32-x86_64.zip
java.io.EOFException: Unexpected end of ZLIB input stream
at java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:223)
at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:141)
at java.util.zip.ZipInputStream.read(ZipInputStream.java:154)
at java.util.zip.ZipInputStream.closeEntry(ZipInputStream.java:100)
at sun.tools.jar.Main.extractFile(Main.java:936)
at sun.tools.jar.Main.extract(Main.java:852)
at sun.tools.jar.Main.run(Main.java:242)
at sun.tools.jar.Main.main(Main.java:1149)
I can see that the file size is OK, I downloaded it several times to verify that its OK, download them from different mirror site and did the same in Window 7 and XP with no success.
Can you please assist?]]>Yaniv Levi2012-09-03T13:50:16-00:00Re: eclipse classic Unexpected end of ZLIB input stream
https://www.eclipse.org/forums/index.php/mv/msg/372401/907215/#msg_907215
not using the right unzip tool; the built-in windows one is known to
work poorly.
On 03/09/2012 3:50 PM, Yaniv Levi wrote:
> 2. WinRar
> at
> at
> at
> Can you please assist?]]>Ed Merks2012-09-03T14:39:11-00:00Re: eclipse classic Unexpected end of ZLIB input stream
https://www.eclipse.org/forums/index.php/mv/msg/372401/907225/#msg_907225
I can unzip any other files or older eclipse version but not this one.]]>Yaniv Levi2012-09-03T15:11:08-00:00Re: eclipse classic Unexpected end of ZLIB input stream
https://www.eclipse.org/forums/index.php/mv/msg/372401/907239/#msg_907239
that the download itself is generally bad or no one would have been able
to unzip it. You're sure you're trying to unzip the one you've tried
redownloading? I.e., delete the old one and try again? I'm not sure
how to get the SHA1 from it, but it's worth checking that it has the
expected MD4 or SHA1...
On 03/09/2012 5:11 PM, Yaniv Levi wrote:
> As you can see from my problem description I took the guidelines from
> eclipse.newcomers.
> I can unzip any other files or older eclipse version but not this one.]]>Ed Merks2012-09-03T15:40:18-00:00
