Eclipse Community ForumsEGit Annotations Across All Branches
https://www.eclipse.org/forums/index.php/mv/msg/369816/902977/#msg_902977
There have definitely been other changes to this file before this branch was created, but none of them appear using annotations. Is there any way to ensure that changes on ALL branches are properly annotated using Team > Show Annotations with EGit?]]>Matt Donnelly2012-08-21T13:49:11-00:00Re: EGit Annotations Across All Branches
https://www.eclipse.org/forums/index.php/mv/msg/369816/908322/#msg_908322
If you think that that is not the case, there may be a bug. What do you see if you open the commit in the Commit Viewer and double click on the file?
If you want to see a list of commit which changed the file you can do that in the History View. Select Team > Show in History. In the History View, select the filter button "Show all changes of selected resource and its children" [1].
[1] http://wiki.eclipse.org/EGit/User_Guide#Working_with_the_Filter_Settings]]>Stefan Lay2012-09-05T06:55:27-00:00Re: EGit Annotations Across All Branches
https://www.eclipse.org/forums/index.php/mv/msg/369816/908651/#msg_908651
> I'm trying to use EGit to do an Annotation across all branches in Eclipse. For instance, we just created a new remote branch, and only one commit has been made on this
> branch for a file. Now, the entire file appears to annotate with the same commit.
