Eclipse Community ForumsDynamic Context Menus not working in Eclipse 4.2
https://www.eclipse.org/forums/index.php/mv/msg/369759/902790/#msg_902790
I am creating a dynamic context menu using dynamic menu contributor. But I have a property tester to determine whether to contribute these items or not. I am using this property tester inside visibleWhen condition.
It is working perfectly in Eclipse 3.x but not in 4.2. Find the attached sample plugin with a Simple View to re-produce the issue.
In the sample application, Dynamic Items will be visible only if you select node 'Three'. But in 4.2, dynamic items are visible always.]]>Ramesh Nachimuthu2012-08-20T13:18:42-00:00Re: Dynamic Context Menus not working in Eclipse 4.2
https://www.eclipse.org/forums/index.php/mv/msg/369759/902859/#msg_902859
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=UI
PW
]]>Paul Webster2012-08-20T18:27:31-00:00Re: Dynamic Context Menus not working in Eclipse 4.2
https://www.eclipse.org/forums/index.php/mv/msg/369759/902964/#msg_902964
I have created a bug in Bugzilla.
